Please find below the list of improvements:
SPR | Brief Description |
1236798 | Resolved Error 20 issue on the Home palette of DraftSight. |
1235888 | Fixed crash when opening files created in AutoCAD. |
1235385 | Resolved Error 1722 when installing DraftSight. |
1235011 | Fixed issue of highlighting entities when editing a block. |
1234924 | Fixed crash when opening a specific DWG file. |
1234914 | DraftSight Mechanical: Resolved issue with On inactive layergroup check box when you click it more than once. |
1232389 | Resolved issue with RemoveAttribute command. |
1231834 | Resolved issue when opening a specific DWG file. |
1231756 | Resolved issue with the position of Associative Pattern entity when using Scale command. |
1231460 | Resolved issue while opening DWG files when using DraftSight with GEOVIA Surpac. |
1231190 | Resolved issue when editing a pattern created AUTOCAD when you save the file containing the pattern in DraftSight and reopen it in AutoCAD. |
1231070 | Resolved issue with PDF Export to make it as accurate as print to PDF. |
1228432 | Resolved issue when using the Move command when ESnap is turned ON. |
