2022 SP1 Release Notes
The list of improvements:
SPR
Brief Description
1227250
Associative Pattern command is available in DraftSight Professional.
1225862
Fixed crash when opening the DWG file.
1225565
Fixed crash when saving changes in custom block that are converted from dynamic block.
1224145
Resolved issue with mouse gesture wheel.
1221963
Resolved Round tripping issue between AutoCAD and DraftSight for a 2018 drawing that includes MTEXT entities and the ‘Text Frame’ property set.
1221682
Resolved issue with automatically changing Paper Size set in Print Configuration setting.
1221527
Resolved issue with the default file path when attaching an image.
1220390
Fixed crash when adding dimension to xref file.
1219871
Resolved issue with SWPDM DraftSight to PDF (SWPDFTaskAddin) task.
1219655
Resolved crash when opening a DWG file by drag and drop when other files are not open in the graphics area.
1217424
Resolved issue with inserting Nuts and Holes in layers.
1214120
Resolved issue when opening a file with filename that has foreign language characters.
1212433
Resolved issue when adding\\removing add-ins from the DraftSight add-in list when user does not have full permissions to addinConfigs folder.
1211050
Fixed crash when opening the specific svg file created in Matterport.
1195537
Resolved issue when multi-selecting entities when using TRIM and SPLIT commands.
