Dear all,
Welcome to DraftSight 2022!
This new release further easies your transition from AutoCAD and helps accelerate your large and complex projects. Here are more details on the Service Pack 0 (SP0) release which is going live at the end of November, 2021. Please stay tuned for more exciting enhancements in the upcoming Service Packs.
Here is a list of fixed issues besides the exciting new enhancements such as Custom Blocks, Pack&Go and Dark Mode.
SPR | Brief Description |
1217225 | Resolved issue when opening specific DraftSight files. |
1214914 | Resolved issue when exploding a specific block that is attached in a specific DWG file. |
1214849 | Shorten the number of recent files per customer feedback, to avoid displaying an overwhelmingly long list. |
1214120 | Resolved issue when opening a specific file whose name includes non-English language characters. |
1211791 | Add the command Paste at the Source Position under the Edit menu. |
1211331 | Keep the block settings when editing a specific file. |
1207587 | Resolved coloring issue when exporting to PDF when monochrome.ctb is used as a print style. |
1207268 | Resolved issue when displaying all layers using the * option in the command window. |
1206528 | Reworded the warning message to avoid confusion when uninstalling DraftSight when there is an active license. |
1204158 | You can now switch to a Dark Mode display to reduce eye strain. |
1201702 | Fixed crash when working with specific dynamic blocks. |
1183471 | Resolved performance issue of DraftSight when you copy/paste specific files. |
1171588 | Resolved issue with selection using left mouse when you open DraftSight on the second monitor at 150% DPI or higher |
912311 | You can now pack a file and its referenced files using the Pack and Go command. |
674555 | Resolved issue when multi-selecting entities when using TRIM and SPLIT commands. |
593449 | Resolved issue when editing P4 multileaders. |
1212521 | Resolved issue when rotating the viewport at a certain angle. |
1208608 | Resolved issue with specific Visual Lisp (VL) functions. |
1213562 | The Dimension Bounding Box command was added under Dimension command list on the Mac OS |
1212859 | Enabled the Import PDF option for the DraftSight Enterprise version. |
1207757 | Enabled Associative Pattern in DraftSight Professional and DraftSight Enterprise |
1213302 | Avoid an unnecessary saving message when closing the file after maximizing or minimizing DraftSight. |
