DraftSight 2021 SP1 Release Notes
The list of improvements:
SPR | Brief Description |
Fixed issue with DraftSight Cartesian Coordinate System when working in the sheet space. | |
1195630 | Resolved issue with storing the options in the toolbar when SOLIDWORKS PDM add-in is enabled. |
1198836 | Fixed issue with Insert Frame command when working in foreign language. |
1199353 | Fixed issue with flipping the dynamic block. |
1199450 | Fixed issue with the DWG file that contains proxy entity when displaying it using PDF Export and Print to PDF. |
1202027 | Fixed issue when importing the XML file with layer for text. |
1202256 | Fixed issue with the random behavior of replaced element when you change levels when editing a pattern. |
1204019 | Added more command variables to control the state of drawings, options and preferences in commands, aspects of the user interface, and settings for drawing, editing, and viewing modes. |
1205238 | Reference task pane reflects the changed names of references immediately. |
1205982 | Help mentions that Associative Patterns is available with Premium and Enterprise Plus. |
1198549 | In EDITCOMPONENT mode when you press ‘I’ key, the command assistance window opens in the first attempt. |
1204068 | Fillets gets created on rectangular polyline in in 'Czech' language |
1196606 | The NCOPY command lets you copy entities from References, Blocks, or DGN underlay without exploding. |
1202146 | When you launch DraftSight, the IMPORT tab always contains the SAT command |
1202921 | The Fill option with Specify points boundary settings works correctly. |
1203372 | When you move one of the dimensions of the multiple overlapped dimensions, the extension cord remains connected. |
1205743 | The dimension line is displayed even if you delete the sketch line on which the dimension line was overlapped. |
1202932 | Fixed crash when customizing ribbon interface when you click Manage > Customize > Interface and select the context menus, Rename, Delete, or Duplicate. |
1207101 | The borrowed DraftSight SolidNetWork license can be returned. |
