DraftSight 2021 SP0 Release Notes
The list of improvements:
SPR | Brief Description |
1190593 | Fixed data extraction issue with EXTRACTBLOCKATTRIBUTE command when attribute name in template uses <.> dot symbol. |
1194163 | ExportToSVG API is available that supports drawings with multiple layers and colors. (API) |
1198257 | Resolved issue with Pan option when using the Line command. |
1198537 | Resolved issue with using custom template specified in SmartNew. |
1189553 | Resolved issue with selecting entities or adding dimensions to the drawing. |
1187601 | Fixed issue when using hyphens in a simple note. You can see the difference in the Justify option as Left to Center and as Center to Middle. |
1196700 | Dimension Bounding Box is available in the Annotate tab in Drafting and Annotation workspace. It is also available in Dimension tab in Classic workspace. |
912758 | Improved appearance of geometry obtained with Cloud command. |
912762 | In DraftSight, you can convert polyline to Cloud. |
1180078 | Added API method for offset command (API). |
1196603 | Added functionality to define the quality of raster images and vectors data for built-in PDF printers. |
1196604 | New command, MODELBACKGROUNDCOLOR, is available and it sets the background color of model space. |
1196605 | Print dialog box displays additional options. |
1198742 | Fixed issue with the value of Z-axis of a curve after creating and exploding polyline. |
1182578 | Resolved performance issue with specific layer. |
1191429 | Fixed performance issue when copying and pasting long text from Microsoft Word document into DraftSight multiline note. |
1198942 | Fixed performance issue when creating ordinate dimensions in larger dwg files. |
1041971 | Fixed crash when opening the recovered files. |
1159022 | Fixed crash on secondary monitor when you disconnect the monitor. |
1167548 | Fixed DraftSight permissions error when disabling add-ins. |
1172644 | Fixed corrupt error issue when opening the dwg file. |
1191488 | Fixed crash when zooming in or zooming out. |
1196994 | Fixed error when running the DraftSight Deployment Tool. |
1197184 | Mac issue: Fixed crash when opening a specific file. |
1198662 | Fixed crash when customizing the panel Interface > Ribbons > Panels. |
