2020 SP4 Improvements
DraftSight 2020 SP4 list of improvements:
SPR
Brief Description
SPR 1194726
Fixed issue when setting dimensions to the entities in the file.
SPR 1194136
Fixed issue when smart dimensioning an entity in a block when the complete block is highlighted
SPR 1188560
Performance improved when dimensioning the large DWG files
SPR 1182534
Fixed issue in Dimensions after copying the entities from older version file to the new drawing
SPR 1195576
Fixed issue in enabling the DIM command for LISP to work
SPR 1190341
Fixed issue with the Papersize setting when using the ExportToPdf2 option.
SPR 1192992
Fixed issue when running Fillet command over two selected lines.
SPR 1190013
Fixed issue with running the PEDIT command at the command line.
SPR 1155988
Fixed issue when updating the parameter values in the graphical display
