DELMIA Quintiq 2026 Golden Now Available
Hello! The DELMIA Quintiq 2026 Golden release is now available. The slide decks with highlights per application can be downloaded directly from this post.
⚙️Installer Packages |📝 Release Notes | 🎧DELMIA Radio Episode
Core Software
📝 Release Notes
Sales & Operations Planning SOP
📝Macro Planner
  • Target stock integration: plan the right amount of stock defined by S&OP.
  • Integration with Climatiq: reduce carbon emission in your supply chain.
  • Volume Plan export: Share your plan with external world
Company Planner MasterProductionPlanning
📝Company Planner
  • Supply Chain Visualization Views: complexity made easier with visual guidance.
Scheduler ManufacturingScheduling
📝Release Notes
  • Heat group planning: more flexibility to achieve higher precision.
  • Shop floor Entry client: emulate MES to test Operation Feedback.
  • Application maintenance: small improvements, but many adding up.
Workforce Planner WorkforcePlanning
📝Release Notes
  • New web client for System Maintenance
  • Similar look-and-feel as planning web client
  • Data admins can update and push data changes
Rail Planner RailPlanning
📝Release Notes
  • Revamped tactical optimizer now resolves service conflicts faster and smarter.
  • The ETG now color-codes 4 constraint types and is configurable using color scheme.
  •  Speed restrictions can be applied network-wide and are factored into service time calculations.
