Introduction
This document is intended to provide detail guide on how to modify the VSTA Macro Project code to generate custom NC Documentation output. Also there is custom "MacroDocWizard" VSTA Macro Project provided at the end for reference. It can generate multiple custom file outputs.
Version – Applicable on and before 2025x FD04 (FP)
Pre-requisites: User must be assigned with Leader Role
Licenses –
CSV (Collaborative Industry Innovator)
- NSR (NC Shop Floor Programmer) or any other machining programming Role
<strong>Disclaimer</strong>: Licenses mentioned above are as per 2025x documentation.What is VSTA Macro?
VSTA (Visual Studio Tools for Applications) macros are a feature within the 3DExperience Platform that allows users to automate repetitive tasks and extend the functionality of the platform. These macros are written in C# or VB.Net and can be used to perform a wide range of actions, such as data manipulation, report generation, and user interface customization.
VSTA Project layout
When you open a VSTA macro in Visual Studio, the workspace is similar to a standard C# project, but contains special components.
Solution Explorer
Resources folder structure
Primary example for the files that are uploaded in this folder are the XSLT files for different output file formats and the External Post Processor (Apache FOP converter) setup folder and batch file etc.
VSTA Macro Workflow
1. Generate Data.xml
2. Apply xslt
An XSLT file (Extensible Stylesheet Language Transformations) is a transformation program that converts an XML document into another format—such as HTML, PDF (via XSL-FO), text, Excel, or another XML.
In this project we have XSLT files for HTML, PDF and WORD format.
3. Run Post Processor
- HTML File Format
For HTML generation there is method available in C# language to transform the data.xml into the html output file with the help of XSLT for the format
- PDF File Format
For PDF generation, Apache FOP converter is embedded in the project and triggered at the final stage
4. Save output
After the Output file is generated, all the generated data is stored in the NC files container for saving it in the platform
- All the generated data is also stored in the local folder at below location
C:\\Users\\YOURTRIAGRAM\\AppData\\Local\\Temp\\TempFolderName
Adding new file format in VSTA Macro
Target File Format: The custom NC Document that we want to generate out of VSTA Macro.
Steps for new file format addition
Final Achieved Result
How to Update the VSTA Macro
How to add logo image
How to add resource(XSLT file for target format)
How to edit finish form code
How to add user input in user interface
How to configure the user inputs required based on file type selected
How to make the user input values persistent
How to edit XMLData.cs
Presentation Document
Reference Data
While exploring the VSTA Macro and how to modify it we have developed few custom file output formats. Follow the provided steps to deploy the provided custom macro project that can generate all these custom file outputs.
Download the 3DXML file below
MacroDocWizard_Custom.3dxml Import the file in 3DExperience Platform using "3dxml with Authoring" mode.
Open the Machining Program data for which you want to generate the Technical Documentation
Launch Macros command from Tool Section
Add the imported PLM VSTA Project in Macros library and run "MacroDocWizard" macro
Below is the list of all the available custom file output formats, corresponding XSLT file name and sample output file.
| Sr.No. | Output Format Name | XSLT File Name | Sample Output File |
| 1 | General html (OOTB Output) | ||
| 2 | General html (OOTB Output) | ||
| 3 | General html (OOTB Output) | ||
| 4 | General pdf | ||
| 5 | Simple pdf | ||
| 6 | Simple docx | ||
| 7 | Intermediate pdf | ||
| 8 | Complete pdf |
Author
Person of Contact - @Sheetal MARDE
Special Thanks to @Nicolas SPISS and @Christophe DECIS for providing support in this topic.
Feel free to reach out to me if you have any questions or need more details.
