Transition paths to the 3DEXPERIENCE platform
You are a CATIA V5 user eager to transform new projects through CATIA 3DEXPERIENCE!
Your transition path is made up of 2 progressive sections.
 You will start with short technical videos before going further with e-learnings:
  1. Technical videos on transition
  2. eLearnings on transition
1. Get started with technical videos
Topic Video
Introduction to the 3DEXPERIENCE Platform
In this video, you will learn how to
•Explore basic User Interface
•Explore Compass
•Discover ways to collaborate
•Learn AURA capabilities
Get Introduced to 3DEXPERIENCE CATIA Terms and Conventions
•Access licenses and roles
•Describe app mapping
•Explore CATIA objects
•Explore user interface of 3DEXPERIENCE CATIA
•Create new content
•Access preferences
Work on 3D data in a secured and collaborative platform
•Explore how to search from database
•Save 3D Parts
•Save assemblies
Work Efficiently with Powerful Modelling Capabilities
•Create constraints using Generative Constraint tool
•Leverage Shortcut Toolbar
•Apply fillets using Autofillet tool
•Apply draft using Autodraft tool
•Explore Text Engraving tool
•Use Iteration tool
Manage Views and Ambience of 3D data
•Change ambience of 3D data
•Manipulate and interact with 3D data
•Navigate and control 3D day in 3D environment
•Explore different view using View command
Create and Manage 3D Materials
•Browse and apply materials
•Create core material
•Create covering material
•Modify material
Work with Assembly Design
•Create Engineering Connections
•Create Assembly Pattern
•Explore Assembly Symmetry tool
Explore Product Structure Table
•Visualize product sections using Clipping tool
•Use BI Essentials to display product information
•Navigate product structure using Level Selector
•Analyze assembly using Interference Check
•Use Volatile Ghosting to enhance part infection
•Explore 3D View Filtering to simplify complex assemblies
•Use Product Structure Table
Concurrent engineering for enhanced efficiency
•Leverage Concurrent Engineering
2. Go further with eLearnings:
Transition to the 3DEXPERIENCE platform for Mechanical Designers
In this module, you will learn how to design a new part with the 3DEXPERIENCE platform. You will also learn how to compute weight, create a new part version, replace the original and create a drawing. Finally, you will learn how to manage complex product structures, create product features, manage catalogs and analyze assemblies.
Transition to the 3DEXPERIENCE platform for Surface Designers
In this module, you will learn how to design a new part with the 3DEXPERIENCE platform. It addresses the needs of Surface Designers. You will also learn how to create a new part version, replace the original part and update the product.
