🎓 Success Path: Mechanical Motion Designer
The Mechanical Motion Designer role provides a complete set of applications in order to perform mechanical systems design and validation, based on 3D geometry, assemblies and parts, for any sophisticated mechanism.
🧑‍🤝‍🧑 Your profile
You want to create your design in CATIA and to create Mechanisms on the 3DEXPERIENCE Platform.
You have onboarded on the following roles: 3DSwymer and Collaborative Industry Innovator.
⌚ Estimated time
Onboarding: 2h 30m
🧑‍🏫 Your learning path starts here
Learn how to engineer accurate mechanism motion, composed of sophisticated sheet metal, machined metal parts for tooling and general mechanical applications.
Please find here your success path for Mechanical Motion Designer. If you follow each part of it, you will quickly become an expert.
Explore the Mechanical Motion Designer Role
In this learning module, you will learn the key capabilities of the Mechanical Motion Designer Role to create and manage mechanisms. You will also learn to perform the static study analysis of the components.
<i><strong>Key concepts covered:</strong></i>
📌 Leverage the 3DEXPERIENCE platform collaboration capabilities
📌 Create assemblies using engineering connections
📌 Create and modify simple and macro mechanisms
📌 Create kinematics scenarios using excitations
📌 Animate kinematics simulations
📌 Detect and remove clashes between components
📌 Plot results of kinematics motions
📌 Perform the static study analysis under the static conditions
3DEXPERIENCE Mechanical Motion Designer - Associate
This certification validates knowledge and skills on the Mechanical Motion Designer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on assembly design, simple and complex mechanisms and kinematics scenarios, and performing static study analysis.
Practice CATIA Assembly Design
In this learning module, you will learn how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also learn how to modify the design in the assembly context.
📌 Create and manage assemblies
📌 Manage the positioning of parts
📌 Create engineering connections to specify the degrees of freedom of components
📌 Modify design in the assembly context
📌 Create flexible assemblies
📌 Calculate, declare, and examine the weight distribution of assemblies
📌 Replace components
Practice CATIA Mechanical Systems Design
This module will teach you how to create the architecture of a mechanism using simple wireframe elements and then complete the mechanism by adding 3D representations. You will also learn how to create a more complex mechanism using existing mechanisms, and finally how to animate the result.
📌 Create a new mechanism
📌 Manage the mechanism behavior
📌 Include alternative representations to complete the mechanism
📌 Create a new macro mechanism from existing sub-mechanisms
📌 Animate the mechanism
Master CATIA Assembly Design
This module will introduce you to complex assembly modeling techniques. You will learn how to design a product architecture and manage complex assembly structures. You will also learn how to use advanced features to design parts within an assembly environment and how to analyze interferences.
📌 Analyze interferences
📌 Analyze component links and relations
📌 Design complex products
📌 Design new parts within a product
📌 Manage complex product structures
Practice CATIA Mechanical Systems Experience​​​​​​​
In this module, you will learn how to define behaviors by manually recording an animation and by using laws. You will also learn how to include the analysis of measurements and accelerations. Furthermore, you will learn how to generate traces, swept volumes and snapshots which can be used while reviewing the simulation results.
📌 Create a scenario manually or by using laws
📌 Include measurement and interference analyses
📌 Generate results
📌 Create snapshots for a review
📌 Export the final simulation
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the CATIA Creative Design & Styling - User COMMUNITY:
Our global community for designers, creatives & users of our creative design, surfacing & VR solutions to network and share their knowledge. Here, you can learn about design trends, processes and roles in 3DEXPERIENCE CATIA design and styling, as well as our VR and surface refinement solutions. Plus, you can interact directly with our champions and experts, view tutorials, webinars and event information, and ask questions. Help make this community yours by joining and contributing today.
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
Content type : User Success Path
Brand : CATIA
Role : MMO-OC
