Mechanical & Shape Engineer |
| The CATIA Mechanical & Shape Engineer role allows the users to enhance mechanical product design quality, through a highly accurate & reliable 3D geometry, supporting very large assemblies and complex surface design, including full model-based definition for product manufacturing information as well as human centric design approach. |
๐งโ๐คโ๐ง Your profileYou want to create sheet metal parts and assemblies. You want to create Parts and assemblies. You want to create complex shapes and surfaces. You want to create Mechanisms. You want to do basic simulation. You want to create 3D annotations. You want to use CATIA. |
โ Estimated timeOnboarding: 6h 40m |
๐งโ๐ซ Your learning path starts hereLearn about a complete and powerful set of applications to create and manage sophisticated mechanical products, including advanced surface, 3D annotations and static and kinematkcs simulation. |
Please find here your success path forย Mechanical and Shape Engineer.ย If you follow each part of it, you will quickly become an expert.
| ย | ||
ย | Explore the Mechanical and Shape Engineer RoleIn this learning module, you will learn the key capabilities of the Mechanical and Shape Engineer role to create and easily manage a complex mechanical engineering project Key concepts covered: ๐ Create assembly symmetry ๐ Design a sheet metal part ๐ Design parts using advanced Part and Surface modeling capabilities ๐ Perform a static study ๐ Create 3D Annotations ๐ Create Kinematic Simulations | |
| ย | ||
3DEXPERIENCE Mechanical & Shape Engineer - AssociateThis certification validates your knowledge and skills on the Mechanical & Shape Engineer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on creating different forms of 3D components such as solid and sheet metal parts. You will also be accessed on your ability to modify existing parts, analyze assemblies or parts and animate the mechanisms. Additionally, your knowledge will be tested on creating parts and assemblies for manufacturing purposes. | ||
| ย | ||
| ย | ||
Practice CATIA Part DesignIn this learning module, you will learn how to create 3D models using the CATIA Part Design app. You will also learn how to use different feature-based tools to build a 3D model. Further, you will also learn how to add parameters, reuse data, create models using tables, and modify a model. Key concepts covered: ๐ Create and constrain 2D sketches ๐ Design fully associative models in 3D ๐ Design reusable features ๐ Parameterize a model ๐ Use Multibody Boolean operations | ||
Practice CATIA DraftingThis module will teach you how to create drawings using the Drafting app. You will learn how to create projection views and section views of a 3D model or an assembly and add the required dimensions. Key concepts covered: ๐ Create simple projection views and section views of 3D parts and assemblies ๐ Position the views on a drawing sheet ๐ Add dimensions and annotations to the views | ||
Practice CATIA Assembly DesignIn this learning module, you will learn how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also learn how to modify the design in the assembly context. Key concepts covered: ๐ Create and manage assemblies ๐ Manage the positioning of parts ๐ Create engineering connections to specify the degrees of freedom of components ๐ Modify design in the assembly context ๐ Create flexible assemblies ๐ Calculate, declare, and examine the weight distribution of assemblies ๐ Replace components | ||
ย | Practice CATIA Generative Shape DesignIn this module, you will learn how to use the Generative Shape Design app to create curves and surfaces. You will also learn how to analyze the wireframe and the surface quality and rectify the detected defects and connect the geometries smoothly. Further, you will learn how to apply resilient modeling techniques to facilitate easy updation of part during design change. Key concepts covered: ๐ Create curves and improve the quality of the imported wireframes ๐ Create surfaces based on the wireframe geometries ๐ Assemble, re-limit and connect the surfaces smoothly to achieve the topology ๐ Analyze the surface quality and heal the defects ๐ Apply resilient modeling techniques | |
Practice CATIA Mechanical Systems DesignโโโโโโโThis module will teach you how to create the architecture of a mechanism using simple wireframe elements and then complete the mechanism by adding 3D representations. You will also learn how to create a more complex mechanism using existing mechanisms, and finally how to animate the result. Key concepts covered: ๐ Create a new mechanism ๐ Manage the mechanism behavior ๐ Include alternative representations to complete the mechanism ๐ Create a new macro mechanism from existing sub-mechanisms ๐ Animate the mechanism | ||
Practice CATIA Sheet Metal DesignIn this module, you learn about the importance of sheet metal design. You will learn how to design a sheet metal part and make it ready for manufacturing. You will learn to define the sheet metal parameters and create a part using basic features. Key concepts covered: ๐ Explore different apps used for the sheet metal design and explain their advantages ๐ Define sheet metal parameters ๐ Create sheet metal parts using walls, bends and cutouts ๐ Manage folded and unfolded views ๐ Create stamped features and flanges ๐ Prepare part for manufacturing with sheet metal order process, DXF file and drawings ๐ Manage the design change | ||
Practice SIMULIA Static StudyThis course is an introduction to performing linear static simulations in the 3DEXPERIENCE Platform. The Static Study app enables designers to perform strength and deflection calculations under static conditions to validate product performance to guide design modifications. Designers can experience product performance virtually so that they can make better-informed design decisions early in the design cycle, when the cost of design change is low and opportunity is high. Key concepts covered: ๐ Search for simulation data in the database ๐ Open the simulation for modification ๐ Perform a simulation using the Static Study app ๐ Review simulations stored in a database and generate reports | ||
| ย | ||
| ย | ||
ย | Master CATIA DraftingThis module will teach you how to manage drawing sheets and views in the Drafting app. You will also learn how to use advanced tools to dress-up, annotate views and customize the Drafting app. Key concepts covered: ๐ Finalize the drawing sheet ๐ Work with large assemblies ๐ Customize the drafting app ๐ Perform administrative tasks ๐ Add Bill of Material | |
Practice CATIA Engineering Templates ReuseIn this module, you will learn how to create customized features by reusing the power copy and user feature. Key concepts covered: ๐ Create customized features using templates | ||
Practice CATIA Quality Rules ReuseIn this module, you will learn how to share corporate knowledge stored in the rule bases and leverage it across the company to ensure design compliance with the established standards. You will also learn to create reports and manage their template. Key concepts covered: ๐ Automate the design modifications ๐ Analyze and create reports | ||
Practice ENOVIA Design ReviewโโโโโโโThis module will teach you how to create different slides for various positions of an assembly to create exploded views. You will also learn how to create sections and measures and export them as parts or drawings. You will also learn how to compare 3D objects and how to create multi-context reviews. Key concepts covered: ๐ Create a design review and add markups to it ๐ Create slides and add markers ๐ Create and export sections and measures ๐ Compare 3D Objects and 2D Drawings ๐ Create multi-context reviews | ||
Practice CATIA 3D Tolerancing and AnnotationโโโโโโโIn this module, you will learn how to annotate a 3D part. You will learn how to create annotation planes and how to add and manage 3D annotations on these planes. You will also learn how to create 3D views and use them to create 2D drawing views. You will also be able to create annotations on assemblies. Key concepts covered: ๐ Add 3D annotations to a part ๐ Manage and position the annotations ๐ Manage the 3D geometry associated to the annotations | ||
Practice CATIA Mechanical Systems ExperienceโโโโโโโIn this module, you will learn how to define behaviors by manually recording an animation and by using laws. You will also learn how to include the analysis of measurements and accelerations. Furthermore, you will learn how to generate traces, swept volumes and snapshots which can be used while reviewing the simulation results. Key concepts covered: ๐ Create a scenario manually or by using laws ๐ Include measurement and interference analyses ๐ Generate results ๐ Create snapshots for a review ๐ Export the final simulation | ||
Practice CATIA Generative Wireframe and SurfaceโโโโโโโThis module will teach you how to use the Generative Wireframe and Surface app to create curves and surfaces. You will learn how to assemble, re-limit and connect the geometries smoothly. You will also learn how to analyze the wireframe and the surface quality and rectify the detected defects. Key concepts covered: ๐ Create curves and improve the quality of the imported wireframes ๐ Create surfaces based on the wireframe geometries ๐ Assemble, re-limit and connect the surfaces smoothly to achieve the topology ๐ Analyze the surface quality and heal the defects | ||
Practice CATIA 2D Layout for 3D DesignโโโโโโโIn this module you will learn how to create 2D layout views in a 3D model and use them to design the part in the 3D environment. Key concepts covered: ๐ Create 2D layout views in a 3D environment ๐ Export 2D geometry into a 3D environment ๐ Create drawings using the 2D layout views | ||
| ย | ||
Strengthen your skills & network with peers! | ||
| ย | ||
๐ Joinย CATIA USER COMMUNITYย to learn more about CATIA and to connect with your peers.Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community! | ย | |
๐ Join theย CATIA Creative Design & Styling - User COMMUNITY:ยOur global community for designers, creatives & users of our creative design, surfacing & VR solutions to network and share their knowledge. Here, you can learn about design trends, processes and roles in 3DEXPERIENCE CATIA design and styling, as well as our VR and surface refinement solutions. Plus, you can interact directly with our champions and experts, view tutorials, webinars and event information, and ask questions. Help make this community yours by joining and contributing today. | ย | |
| ๐ Join theย 3DEXPERIENCE platform user's communityย to learn more about the 3DEXPERIENCE platform and to connect with your peers.Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community! | ย |
๐ Join theย ENOVIA User Communityย to learn more about the ENOVIA brand and to connect with your peers.Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and helpย in our online community! | ย | |
โโโโโโโโโโโโโโโContent type :ย User Success Pathย
Brand :ย CATIAย ย
Role :ย
M3S-OCย โโโโโโโ
