🎓 Success Path: Fluid 3D Systems Designer
The Fluid 3D Systems Designer  is a role that covers the 3D Physical Design and Manufacturing preparation of Routed Systems like Tubing (Hydraulic/pneumatic) Piping and HVAC (Heat Ventilation and Air-conditioning) within the Digital Mockup of a product. It is part of the complete integrated Fluid process and has tight synchronization capabilities with the Systems Schematic Designer role that allows 2D Diagram creation.
It also provides tools to define the physical system of both rigid and flexible pipes and tubes from basic routing definition to detailed design. This is made possible with the help of intelligent part placement based on standard and design rules that comply with company knowledge. In addition, its tools make it possible to quickly query design information and generate reports based on any component parameters. A full digital mock-up ensures design precision while saving time, minimizing errors, and reducing cost.
Together with the 3DEXPERIENCE platform, the Fluid 3D Systems Designer role enables users to manage the design of their fluid systems all the way from conceptual functional design through to producing detailed manufacturing data.
It provides dedicated applications to facilitate piping Specification and Part catalog definition and management. Like all other 3D roles, it contains all core functions to do 3D design, assembly and drawing also review & sectioning tools.
🧑‍🤝‍🧑 Your profile
You want to be able
  • to design and optimize the physical system of both rigid and flexible pipes/tubes and HVAC from basic routing definition to detailed design
  • to implement basic piping and tubing behaviors, relationships, and attributes
  • to design with a highly interactive and intuitive user interface
  • to integrate business rules
You have onboarded on the following roles: 3DSwymer and Collaborative Industry Innovator.
⌚ Estimated time
Onboarding: 6h 25m
🧑‍🏫 Your learning path starts here
Learn how to quickly create and explore innovative conceptual ideas with an integrated creative workflow.
Explore the Fluid 3D Systems Designer Role for Piping/HVAC
In this module, you will learn to create and manage the piping/HVAC specifications and create pipes with respective fittings and equipment.
<i><strong>Key concepts covered:</strong></i>
📌 Identify and create the basic resource set for piping/HVAC specifications
📌 Route pipes between equipment and place fittings on the segments
📌 Perform advanced route analysis
Explore the Fluid 3D Systems Designer Role for Tubing
In this module, you will learn how to design the tubing system. You will learn to use the specification driven approach and automated part placement capabilities to ensure compliance with industry standards. You will also learn to validate the design and generate reports.
📌 Create and manage the fluidic system
📌 Place the parts manually and automatically
📌 Prepare and manipulate flexible tube assemblies
📌 Validate the fluidic design using various tools
📌 Prepare the data for manufacturing
3DEXPERIENCE Fluid 3D Systems Designer – Associate
This certification validates your knowledge and skills on the Fluid 3D Systems Designer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on creating fluidic system, placing the parts, validating the fluidic design using various tools and preparing the data for manufacturing.
Practice CATIA Piping and Tubing 3D Design
This module will teach you how to route a pipe or a tube, and place the piping components. You will learn how to detail the design and modify the network. You will also learn how to validate the design and prepare it for manufacturing. The module also features exercises that enable you to practice creating a piping system design.
📌 Route straight pipes or tubes
📌 Position piping or tubing parts
📌 Adjust the design of a piping or a tubing network
📌 Validate the piping and tubing design
📌 Prepare the piping and tubing design for manufacturing
Practice CATIA Piping and Tubing Setup
This module will teach you how to set up fluid systems resources and create piping components. You will learn how to manage component catalogs, design validation rules, and global naming conventions. You will also learn how to customize the generative view style file for drawings and standards for P&ID.
📌 Create and manage resources for fluid systems design
📌 Build equipment, supports, and components
📌 Reuse the piping standard data for design setup
📌 Create and manage component catalogs
📌 Define the global naming conventions
📌 Create the checks and rules for design validation
📌 Create templates for generating reports
📌 Customize the drafting standards and settings
 TBC
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
