🎓 Success Path: Electrical 3D Systems Designer
Explore the Electrical 3D Systems Designer Role for Wire Harness
This learning module provides you with a guided and systematic approach to learn about the use of the Electrical 3D Systems Designer role for wire harness. It will teach you how to synchronize and place electrical components using logical design. It will also teach you how to route branch geometries and cables through them in a wire harness
<i><strong>Key concepts covered:</strong></i>
📌 Assign electrical properties to the 3D parts
📌 Create cable raw materials and store them in a library
📌 Place Electrical components in the Physical design using Logical to Physical capabilities
📌 Create and manage branches to connect the electrical devices and equipment
📌 Route cables through the branch geometries
📌 Check network connectivity between the branches and connectors
3DEXPERIENCE Electrical 3D Systems Designer - Associate
This certification validates your knowledge and skills on the Electrical 3D Systems Designer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on logical to physical synchronization, branch routing, wire routing and analyzing network connectivity.
Practice CATIA Electrical 3D Design
This module will teach you how to create electrical geometry in the 3DEXPERIENCE platform and thereby help you in designing the electrical physical systems. You will work with electrical catalogs to place the components from electrical libraries. You will learn the routing of branches for creating electrical branch geometries, managing the electrical geometry content, and routing conductors through the electrical geometry.
📌 Create and use an Electrical Library using Data Setup
📌 Create an Electrical Geometry
📌 Route Conductors through the Electrical Geometry
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
