🎓 Success Path: CATIA Engineering Master
Mechanical Engineer
The CATIA Mechanical Engineer role allows the users to Enhance your mechanical product design quality & alternatives, Increase the number of studies using  complex mechanism design and static simulation.
🧑‍🤝‍🧑 Your profile
You want to Cover the END-to-END process for mechanical engineering & pre-production studies. You want to Reduce time to market with best in class detailed design apps. You want to Explore innovative solutions and concepts on single parts and large assemblies. You want to Define the right detailed design the first time using existing designs. You want to Anticipate Product Manufacturing Information through the full definition of 3D Tolerances & Annotations in the same model.
You have onboarded on the 3DEXPERIENCE platform
⌚ Estimated time
Onboarding: 5h30m on Engineering and 5h on platform collaboration
🧑‍🏫 Your learning path starts here
Learn how to enhance your mechanical product design quality & alternatives, Increase the number of studies using complex mechanism design and static simulation.
Please find here your success path for Mechanical Engineer. If you follow each part of it, you will quickly become an expert.
Discover the value and usage of your roles and learn about their main apps articulation
Explore the Mechanical Engineer Role
In this learning module, you will learn the key capabilities of the Mechanical Engineer role to create, annotate, simulate and easily manage a complex mechanical engineering design.
Key concepts covered:
📌 Create assembly symmetry
📌 Design a sheet metal part
📌 Perform a static study
📌 Create 3D Annotations
📌 Create Kinematic Simulations
3DEXPERIENCE Mechanical Engineer - Associate
This certification validates your knowledge and skills on the Mechanical Engineer role within the 3DEXPERIENCE platform. You will be asked multiple-choice questions (MCQ) on creating different forms of 3D components such as solid and sheet metal parts. You will also be assessed on your ability to modify existing parts, analyze assemblies or parts and animate the mechanisms. Additionally, your knowledge will be tested on creating parts and assemblies for manufacturing purposes.
Explore the Project Planner Role
In this module, you will learn how to collaboratively innovate through flexible team-based project planning and execution.
Key Concepts Covered:
📌 Create a Team Project and add members
📌 Add and assign Tasks
📌 Add Task Dependencies and Milestones
📌 Add Project content
📌 Add a Task Deliverable and update the status
📌 Create a sub-project
📌 Add cross-project Dependencies
Explore the Product Release Engineer Role
In this learning module, you will learn how to manage the engineering definition of products from early definition to final validation in collaboration across disciplines to easily complete and validate the product structure to advance product innovation.
📌 Manage Engineering Items
📌 Evaluate Geometry in 3Dplay
📌 Duplicate Engineering Definition
📌 Organize Engineering Content
📌 Initiate Advanced Definition
📌 Execute Design Changes
📌 Implement Work Under Change Action
📌 Release Engineering Definition
Explore the Business Process Player Role
In this learning module, you will learn how to instantiate new processes, execute tasks assigned to you through a business process or monitor process activity.
📌 Manage and execute tasks
📌 Trace Exchange
📌 Monitor business process through graphical view
Deep dive into the most important features of the key Apps and their practical usage in projects
 Watch these technical videos 👉
Discover powerful features of Assembly Design
Discover advanced features of Assembly Design
Discover Life Cycle Management, Data Exchange with OEMs, Task Management, Issue and Change Management, Using Dashboards
Practice CATIA Sheet Metal Design
In this module, you learn about the importance of sheet metal design. You will learn how to design a sheet metal part and make it ready for manufacturing. You will learn to define the sheet metal parameters and create a part using basic features.
📌 Explore different apps used for the sheet metal design and explain their advantages
📌 Define sheet metal parameters
📌 Create sheet metal parts using walls, bends and cutouts
📌 Manage folded and unfolded views
📌 Create stamped features and flanges
📌 Prepare part for manufacturing with sheet metal order process, DXF file and drawings
📌 Manage the design change
Practice SIMULIA Static Study
This course is an introduction to performing linear static simulations in the 3DEXPERIENCE Platform. The Static Study app enables designers to perform strength and deflection calculations under static conditions to validate product performance to guide design modifications. Designers can experience product performance virtually so that they can make better-informed design decisions early in the design cycle, when the cost of design change is low and opportunity is high.
📌 Search for simulation data in the database
📌 Open the simulation for modification
📌 Perform a simulation using the Static Study app
📌 Review simulations stored in a database and generate reports
Practice CATIA Part Design
In this learning module, you will learn how to create 3D models using the CATIA Part Design app. You will also learn how to use different feature-based tools to build a 3D model. Further, you will also learn how to add parameters, reuse data, create models using tables, and modify a model.
📌 Create and constrain 2D sketches
📌 Design fully associative models in 3D
📌 Design reusable features
📌 Parameterize a model
📌 Use Multibody Boolean operations
Practice CATIA Drafting
This module will teach you how to create drawings using the Drafting app. You will learn how to create projection views and section views of a 3D model or an assembly and add the required dimensions.
📌 Create simple projection views and section views of 3D parts and assemblies
📌 Position the views on a drawing sheet
📌 Add dimensions and annotations to the views
Practice CATIA Assembly Design
In this learning module, you will learn how to create and manage assemblies and sub-assemblies in the design context. You will manage the positioning of parts and analyze assemblies. You will also learn how to modify the design in the assembly context.
📌 Create and manage assemblies
📌 Manage the positioning of parts
📌 Create engineering connections to specify the degrees of freedom of components
📌 Modify design in the assembly context
📌 Create flexible assemblies
📌 Calculate, declare, and examine the weight distribution of assemblies
📌 Replace components
Practice CATIA 3D Tolerancing and Annotation​​​​​​​
In this module, you will learn how to annotate a 3D part. You will learn how to create annotation planes and how to add and manage 3D annotations on these planes. You will also learn how to create 3D views and use them to create 2D drawing views. You will also be able to create annotations on assemblies.
📌 Add 3D annotations to a part
📌 Manage and position the annotations
📌 Manage the 3D geometry associated to the annotations
Practice CATIA Generative Wireframe and Surface​​​​​​​
This module will teach you how to use the Generative Wireframe and Surface app to create curves and surfaces. You will learn how to assemble, re-limit and connect the geometries smoothly. You will also learn how to analyze the wireframe and the surface quality and rectify the detected defects.
📌 Create curves and improve the quality of the imported wireframes
📌 Create surfaces based on the wireframe geometries
📌 Assemble, re-limit and connect the surfaces smoothly to achieve the topology
📌 Analyze the surface quality and heal the defects
Practice CATIA Mechanical Systems Design​​​​​​​
This module will teach you how to create the architecture of a mechanism using simple wireframe elements and then complete the mechanism by adding 3D representations. You will also learn how to create a more complex mechanism using existing mechanisms, and finally how to animate the result.
📌 Create a new mechanism
📌 Manage the mechanism behavior
📌 Include alternative representations to complete the mechanism
📌 Create a new macro mechanism from existing sub-mechanisms
📌 Animate the mechanism
Practice CATIA Quality Rules Reuse
In this module, you will learn how to share corporate knowledge stored in the rule bases and leverage it across the company to ensure design compliance with the established standards. You will also learn to create reports and manage their template.
📌 Automate the design modifications
📌 Analyze and create reports
Enrich your usage through advanced apps or additional roles
                             EXPAND your capabilities with advanced apps of your role
Practice CATIA Mechanical Systems Experience​​​​​​​
In this module, you will learn how to define behaviors by manually recording an animation and by using laws. You will also learn how to include the analysis of measurements and accelerations. Furthermore, you will learn how to generate traces, swept volumes and snapshots which can be used while reviewing the simulation results.
📌 Create a scenario manually or by using laws
📌 Include measurement and interference analyses
📌 Generate results
📌 Create snapshots for a review
📌 Export the final simulation
                                  EXPAND your capabilities with additional roles
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join the 3DEXPERIENCE Platform User Community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
