Following pages are describing the Bussiness Logic (BL) defined into the datasetup and that are called by Schematic application to adjust commands behaviors
Important :
if you have 2 rules that address the same type of object and that are attached to 2 resources of the same type , then the application is taking only the first one
In this case you must have the 2 codes inside the same rules
// Rule1 set ... //---------------------------------------- // Rule2 set ....
