Introduction
When routing a pipe route or editing it , different options are available
- you can starting or end the routing from/to
- a component port
- any where whitout connecting it to a port
- using an on-off Sheet connector
- you can select the routing mode
- free
- angular
- orthogonal
The pipe route can be stoped in one sheet and be continue in another sheet (the same pipe instance will be then multi represented in multiple P&ID sheets
Also Graphic properties of the pipe line can be parametrize to be driven by objec tattributes
let's see some of the capabilities with videos
