Machining Solutions
Thanks to the entire complete product portfolio and due to the easy to use knowledge based V5 architecture, CATIA V5 Machining surpasses all the existing industry proven suites of NC Manufacturing applications.
Domain Objective
Working together with our partners, CATIA V5 Machining delivers best-in-class products and solutions that enable manufacturing industries to plan, detail, simulate and optimize their machining activities to build better products.
Machining Domain Overview
High efficiency in part programming... Thanks to tight integration between tool path definition and computation, tool path verification and output creation the user can boost production quality by machining the right part, first time. Machining operations, supported by multiple passes and levels and automated rework in roughing and finishing also enhance this ability.
Effective change management... This solution set possesses a high level of associativity between product engineering and manufacturing processes and resources (PPR). Companies can therefore manage concurrent engineering and manufacturing flows better and reduce the length of the design to manufacturing cycle and then saving costs.
High level of automation and standardisation... By integrating the pervasive knowledgeware capabilities of CATIA V5 (in manufacturing intent and macro storage, for example), NC products allow the capture of skills and reuse of proven manufacturing knowledge and avoid repetition. This also facilitates innovation through shortened test cycles.
Optimised tool paths and reduced machining time... CATIA V5 NC products offer a wide set of flexible high-speed machining operations such as concentric roughing, Z-level milling, spiral milling and 5-axis flank contouring. This decreases the time needed to execute shop floor operations.
Easy to learn and easy-to-use products... As a result of an intuitive user interface, users are trained faster and then use the full breadth of CATIA V5. Ease of use brings hard fun!
Reduced administration costs and skills efforts... CATIA V5 Machining solution can be used as a single system to cover a wide set of integrated applications, fom lathe to 5-axis milling. This allows companies to institute strong, manageable and long-term partnerships with their CATIA CAM supplier.
Machining Product List
These products are available in several platform levelsP1P2P3
CATIA - NC Machine Tool Builder
MBG
CATIA - NC Machine Tool Simulation
MSG
CATIA - NC Manufacturing ReviewNG1NCG
CATIA - Prismatic Machining Preparation Assistant
MPA
CATIA - Prismatic MachiningPG1PMG
CATIA - 3-Axis Surface Machining
SMG
CATIA - Multi-Axis Surface Machining
MMG
CATIA - Multi-pocket Machining
MPG
CATIA - Advanced Machining
AMG
CATIA - Lathe MachiningLG1LMG
CATIA - Multi-Slide Lathe Machining
MLG
CATIA - NC Manufacturing Verification
NVG
CATIA - STL Rapid PrototypingTL1STL​​​​​​​
