🔓 Gain Access to eLearning Content, Certification and Support
3DEXPERIENCE Edu Space is the Dassault Systèmes eLearning portal, accessible at the following URL: https://eduspace.3ds.com. Since it is available online, learners can log in from anywhere, at any time. Learners can access a list of training materials tailored to their roles, profiles, and business needs.
Edu Space Login
Here are three login options:
1.Sign in using a registration voucher
As a learner, you must have received a link with a voucher code to have access to EduSpace. The link you received look like this one*. This link opens a new page with the voucher code already prefilled.
A 3DEXPERIENCE account is a prerequisite for using Eduspace. If you already have a 3DEXPERIENCE ID, you can select “I am an existing user” and log-in using your credentials (3DEXPERIENCE ID). If not, you can then proceed to Registration and a page will prompt you to create an account when connecting to Edu space.
<span class="cke-highlighted" style="background-color:#ffff00">*</span>This link is sent to a customer admin or a partner admin who ordered at least of the learning product (learning libraries) with or without certification credits (CRLX-OC product item). The customer or partner admin receives (after implementing his order) an access link (like the one above) to distribute to his users.
Check out the video for instructions on signing in with a registration voucher.
2.Log in using your organization's portal
3.
Login in using your Edu Space ID
⚠️ This mode is only used for few legacy existing users, we recommend you to log-in with a 3DEXPERIENCE ID or to create one to access
Learner Dashboard - HOME Tab
The Home panel is divided into three zones, allowing you to access your Recent Learnings, Assignments, and Favorites:
  • Recent Learnings Zone: Displays your most recently visited learning paths and available content.
  • Assignments Zone: Shows the enrollments assigned to you by an Administrator, including those that need to be completed and those that have expired.
  • Favorites Zone: Displays the learning content you have marked as your favorites.
___________________________________________________________________________________________________________
Learner Dashboard - LEARNING CATALOG Tab
LEARNING CONTENTS
The Catalog displays Learning Paths, Learning Modules, and Certifications available for your role(s) and profile. Learning Paths include several Learning Modules and may also have Certifications.
Two viewing options are available for the catalog.
All Contents: A collection of Learning Paths, Learning Modules and Certifications
Library Based: Consolidated learnings based on your Libraries
   1. Display the Learning Path/Learning Module
        Click the title to display Learning Path or the Learning Module content and its details.
Top Bar: Displays details of the Learning Path/Learning Module, including progression, duration, and release information
Content Tab: Shows the lessons that make up the course, along with their duration and your progress and status for each
Details Tab: Provides the course description, objectives, version, duration, audience, course code, level, and available languages
   2. Choose a Language in a Learning Path/Learning Module
  • To run a Learning Path/Learning Module in a language other than English, select your preferred language from the drop-down menu.
  • You can also set a default language for your courses. To do this, navigate to the My Settings menu or refer to the User Settings section.
  • If only one language is available, it indicates that the Learning Path/Learning Module is offered exclusively in that language.
   3. Choose a Version in a Learning Path/Learning Module
  • When searching for a Learning Module or Learning Path, a notification will appear on the card indicating the number of additional versions available if multiple versions exist (e.g., "+2 more" following the latest version).
  • To run a Learning Path/Learning Module in a version other than the latest, select the desired version from the drop-down menu.
  • If only one version is available, it means the Learning Path/Learning Module exists solely in that version.
CERTIFICATIONS
Here’s a brief overview of your journey from enrolling in a certification to being recognized for your accomplishments.
1. Enrollment
Check out the video to learn how to enroll in a certification.
Note: In some instances, you may need to enter a certification code to complete your enrollment. This code (CERTXXXXXX) is provided by the company or partner to their learners and is valid for one certification only.
2. Assessment
After enrolling in a certification, the Enroll button will change to a Take Exam button, enabling you to launch and begin the exam.
Note: Before you start the exam, you can still cancel your registration if you decide it’s not the right certification for you. Canceling will restore the original credits to your organization's pool as if they were never used. However, once you click on Take Exam, you won't be able to cancel your enrollment.
3. Completion
  • If you achieve the required score at the end of the exam, Congratulations! You are now certified!
  • For certifications that offer a digital badge, you can retrieve your badge to officially validate your achievement.
  • Badges are generated and issued through "Credly," allowing you to view and manage your accreditations for various certifications.
  • Some certifications provide a PDF certificate instead of a digital badge.
4. Recognition
Once you've successfully completed the exam, you'll receive a badge that you can share on your social media profiles. Here's a quick overview of how to claim your badge and share it.
Ask for Support on Edu Space
If you have access issues to Edu Space, please contact your platform ADMIN or your partner.
You can also use the 3DSupport App (tutorials are available here).
