Context
Some CATIA Applications profides command to display in a spreadsheet view the object of your session with all their attributes
you can edit them in the view directly or export them in XLS / CSV format
Then they can be modified and reimported into the platform
- The import command is under variable because it request to be rigorous especialy with the object internal names (UUID). The reimport will create or overide the existing data in database without any control
Here are some exemple of usage of such Spreadsheet editor command tha tis available in the Piping 2D and 3D design Apps
Schematic usage exemple:
create line ID list
3D Space usage exemple
Create 3D Space breakdown structure
see chapter : "XLS Import - Export GBS Data structure and attributes (no geometry) through XLS" in this page :
Administration
