EKL - Color 3D Piping objects
Introduction
Purpose: color 3D objects (Pipe or Part or insulation)
3 different use cases: the automation of the coloring can be done either
  • as a rule imbedded into the part that is executed based on attribute/parameter value
  • as a post processing user action launched manually
  • as an automatic Business rule launched at the creation of the object instance
let's see different examples for each use case and needs
Note: for pipes make sure that the following Preference is selected: "Copy color from route reference"
USE CASE1: Color automatically reference part in catalog
Need
We want to drive the color of the the Piping Part & Piping Pipe 3D geometry based on a predefined code color set on a parameter inside the part that can be driven by a design table
Each pipe and part will have a predefined color based on the value of Nominal size
Case for Part
For Piping part it is very easy , you just have to create a simple rule to color the PartBody using ".Color(R,G,B)
Rule Code :
PartBody.SetColor(Color)
Case for pipes
For pipe is much more complex because you don't have acces to the 3D volume. The only way is to use the SetColor method that is applied on the Piping_Rigid_Pipe VPMReference object
This method need as inputs RGB color where R,G,B are 3 integers
in our case the PArameter is R,G,B string so we will need to decompose it to use it
Rule code :
<strong>let</strong> MyProduct (VPMReference)
<strong>let</strong> MyShape (VPMRepReference)
<strong>let</strong> MyShapeInst(VPMRepInstance)
<strong>let</strong> MyPiping(Piping_Rigid_Pipe)
// Find Root
<strong>let</strong> roots(List)
<strong>let</strong> rootOfEditor(VPMReference)
<strong>let</strong> lOcc(List)
<strong>let</strong> rootOccurrence,findOcc(ProductOccurrence)
roots = GetEditorRoots("VPMReference")
<strong>if</strong> roots->Size() == 1
<strong>{<!-- --></strong>
                rootOfEditor = roots[1]
<strong>}</strong>
// Find VPMReference from feature
<strong>let</strong> lRepInsts(List)
<strong>let</strong> lRepRefs(List)
MyShape=GetPLMOwner(PartBody)
//Message("Shape: ", MyShape.V_Name)
lRepInsts = MyShape->ListInstances(rootOfEditor)
<strong>if</strong> (lRepInsts.Size() > 0)
                <strong>set</strong> MyShapeInst = lRepInsts[1]
<strong>}</strong>
<strong>set</strong> MyProduct = MyShapeInst.Owner
//Notify("MyProduct : #",MyProduct.Name)
<strong>set</strong> MyPiping = MyProduct
//Convert string "R,G,B" to integer list (R,G,B)
<strong>let</strong> RGBColor,CodeColor,separator(String)
<strong>let</strong> RGBList(List)
<strong>let</strong> separatorPosition,NextseparatorPosition,i(Integer)
//Split RGB string with ","
separator = ","
RGBColor =PipeColor
i=1
separatorPosition=0
NextseparatorPosition=0
<strong>for</strong> i <strong>while</strong> NextseparatorPosition <> RGBColor.Length()
                NextseparatorPosition = RGBColor.Search(separator,separatorPosition)
                <strong>if</strong>(NextseparatorPosition==-1)
                                NextseparatorPosition = RGBColor.Length()
                CodeColor=RGBColor->Extract(separatorPosition,NextseparatorPosition-separatorPosition)
                RGBList.Append(CodeColor)
                separatorPosition = NextseparatorPosition + 1
<strong>}</strong>
//Notify("ListRGB.Size() = ", RGBList.Size())
// Convert R, G and B strings to Integers
<strong>let</strong> R(Integer)
<strong>let</strong> G(Integer)
<strong>let</strong> B(Integer)
<strong>let</strong> R_St(String)
<strong>let</strong> G_St(String)
<strong>let</strong> B_St(String)
R_St=RGBList->GetItem(1)
G_St=RGBList->GetItem(2)
B_St=RGBList->GetItem(3)
//Notify("R = #, G = #, B = #", R_St, G_St, B_St)
<strong>Set</strong> R=R_St.ToReal()
<strong>Set</strong> G=G_St.ToReal()
<strong>Set</strong> B=B_St.ToReal()
//Notify("R = #, G = #, B = #", R, G, B)
MyPiping.SetColor(R,G,B)
USE CASE2 :  Post processing rule/action
Need1 : Color pipe based on lineID Name
Simple case : Color pipe based on lineID Name with the name of lineID is hardcoded inside the rule
Code Example:
let iRefLineID(String)
let iPipe(Piping_Rigid_Pipe)
iRefLineID=iRef->GetLineIDName()
iPipe=iRef.Reference
if (iRefLineID == ("PL001"))
    iPipe.SetColor(255,255,128)
else if (iRefLineID == ("PL002"))
    iPipe.SetColor(255,128,68)
else if (iRefLineID == ("PL003"))
    iPipe.SetColor(128,128,192)
Need2 : Color pipe based on LineId Fluid Name
advanced : Color Pipe based on LineId Fluid Name (from Techno table)
Code Example:
/* Prototype: (Void) : #Void */
/* Requirement: This code relies on an additional column in the fluid table (OutfittingColor) */
/* OutfittingColor column will contain the RGB color code for each fluid */
/* Comment: Mind switching ON action's property 'No dialog box when running an action without argument' */
let MessageCatalogName(String)
let MessageContent(String)
let RootOccurrence(ProductOccurrence)
let RootReference(VPMReference)
let RootOccurrenceList(List)
let RootReferenceList(List)
let CachedFuildTable(VolatileInstance)
let FluidTable(Ens_FluidTable)
let ColumnDescriptors(List)
let ColumnDescriptor(EnsParameterDescriptor)
let FluidColumnIndex(Integer)
let ColorColumnIndex(Integer)
let CellsList(List)
let FluidCell(EnsTechnologicalTableCell)
let ColorCell(EnsTechnologicalTableCell)
let Fluid(String)
let Color(String)
let NbColumns(Integer)
let NbRows(Integer)
let DuctsList(List)
let PartsList(List)
let PipeOccurrence(Piping_Pipe_Occurrence)
let PartOccurrence(Piping_Part_Occurrence)
let GraphicManager(Visualizable)
let LineID(Piping_Line)
let Count(Integer)
let I(Integer)
MessageCatalogName = "CDVEKLMessageCatalog_Piping"
Count = 0
set CachedFuildTable = new("VolatileInstance", "", NULL)
set FluidTable = AccessResource("PipingSpecificationResource|Fluid", "Ens_FluidTable")
if FluidTable <> NULL
    I = 1
    FluidColumnIndex = 0
    ColorColumnIndex = 0
    FluidTable->GetColumnDefinitions(ColumnDescriptors)
    for I while I <= ColumnDescriptors->Size()
        set ColumnDescriptor = ColumnDescriptors->GetItem(I)
        if ColumnDescriptor == NULL
            continue
        /* XXX: Fluid table column names and types are hardcoded here... */
        if ColumnDescriptor.Type <> "String"
            continue
        else if ColumnDescriptor.Name == "Fluid"
            FluidColumnIndex = I
        else if ColumnDescriptor.Name == "OutfittingColor"
            ColorColumnIndex = I
    if FluidColumnIndex == 0 or ColorColumnIndex == 0
        MessageContent = BuildMessageNLS(MessageCatalogName,"PIP_0002_ERR_FluidTableMissingColors" , I - 1, Count)
        if MessageContent->Length() <= 0
            Notify("Piping fluid table does not defined any colours for outfitting...")
        else
            Notify(MessageContent)
        exit
    I = 1
    FluidTable->GetSize(NbRows, NbColumns)
    for I while I <= NbRows
        if FluidTable->GetRow(I, CellsList) == false
            continue
        set FluidCell = CellsList->GetItem(FluidColumnIndex)
        set ColorCell = CellsList->GetItem(ColorColumnIndex)
        if FluidCell == NULL or ColorCell == NULL
            continue
        Fluid = FluidCell->GetAttributeString("ValueAsString")
        Color = ColorCell->GetAttributeString("ValueAsString")
        CachedFuildTable->SetAttributeString(Fluid, Color)
else
    MessageContent = BuildMessageNLS(MessageCatalogName,"PIP_0001_ERR_FluidTableNotDefined")
        Notify("No fluid table defined for Piping...")
    else
/* XXX: Improve this by retrieving active level's root parent? */
RootReferenceList = GetEditorRoots("VPMReference")
if RootReferenceList->Size() == 1
    set RootReference = RootReferenceList->GetItem(1)
if RootReference <> NULL
    set RootOccurrenceList = RootReference->ListOccurrences(RootReference)
if RootOccurrenceList <> NULL and RootOccurrenceList->Size() == 1
    set RootOccurrence = RootOccurrenceList->GetItem(1)
if RootOccurrence <> NULL
    I = 1
    set DuctsList = RootOccurrence->Query("Piping_Pipe_Occurrence", "")
    set PartsList = RootOccurrence->Query("Piping_Part_Occurrence", "")
    for I while I <= DuctsList->Size() + PartsList->Size()
        set LineID = NULL
        set GraphicManager = NULL
        if I > 0 and I <= DuctsList->Size()
            set PipeOccurrence = DuctsList->GetItem(I)
            if PipeOccurrence == NULL
                continue
            set LineID = PipeOccurrence->GetLineIDObject().Reference
            set GraphicManager = PipeOccurrence
        else if I <= DuctsList->Size() + PartsList->Size()
            set PartOccurrence = PartsList->GetItem(I - DuctsList->Size())
            if PartOccurrence == NULL
                continue
            set LineID = PartOccurrence->GetLineIDObject().Reference
            set GraphicManager = PartOccurrence
        if GraphicManager == NULL
            continue
        if LineID == NULL
            GraphicManager.Color = "#FFFFFF"
        else if CachedFuildTable->HasAttribute(LineID.V_Fluid) == false
        else
            GraphicManager.Color = CachedFuildTable->GetAttributeString(LineID.V_Fluid)
            Count = Count + 1
    MessageContent = BuildMessageNLS(MessageCatalogName,"PIP_0003_INF_ElementsCountNotification" , I - 1, Count)
        Notify(ToString(I - 1) + " Piping element(s) analysed, " + ToString(Count), " colorised.")
    else
Rules
Need3 :  Color insulation based on "insulation Type" attribute
the value of the color of the insulation is retreive from the "Insulation type" Techno table
Code exemple:
/* Requirement: This code relies on an additional column in the InsulationType table (OutfittingColor) */
let CachedInsulationTypeTable(VolatileInstance) /* Test Insulation */
let InsulationTypeTable(Ens_InsulationTypeTable) /* Test Insulation */
let InsulationTypeColumnIndex(Integer)
let CellsList(List)
let InsulationTypeCell(EnsTechnologicalTableCell)  /* Test Insulation */
let Fluid(String)
let InsulationType (String)  /* Test Insulation */
let Color(String)
let NbRows(Integer)
let DuctsList(List)
let PartsList(List)
let InsulationList(List) /* Test Insulation */
let InsOccurence(Piping_Insulation_Occurrence)  /* Test Insulation */
let InsRef(Piping_Insulation) /* Test Insulation */
let Count(Integer)
let I(Integer)
Count = 0
set CachedInsulationTypeTable = new("VolatileInstance", "", NULL)  /* Test Insulation */
// retreive InsulationType table from Datasetup
set InsulationTypeTable  = AccessResource("PipingSpecificationResource|InsulationType", "Ens_InsulationTypeTable") /* Test Insulation */
// Retreive Column index for InsulationType and Color in InsutlationTypeTable
if InsulationTypeTable <> NULL
    I = 1
    InsulationTypeColumnIndex = 0
    InsulationTypeTable ->GetColumnDefinitions(ColumnDescriptors)
            continue
        /* XXX: Insulation Type table column names and types are hardcoded here... */
            continue
        else if ColumnDescriptor.Name == "InsulationType"
            InsulationTypeColumnIndex = I
    // If no InsulationType or OutfittingCollor Collumn in the table , Message
    if InsulationTypeColumnIndex == 0 or ColorColumnIndex == 0
        Notify("Piping Insulation Type table does not defined any colours for outfitting...")
    else
        Notify("InsulationType & OutfittingColor columns found")
    // Build  InsulationType  value list and Color value list for from the Insulation Table
    I = 1
    InsulationTypeTable->GetSize(NbRows, NbColumns)
        if InsulationTypeTable->GetRow(I, CellsList) == false
            continue
        set InsulationTypeCell = CellsList->GetItem(InsulationTypeColumnIndex)
        if InsulationTypeCell == NULL or ColorCell == NULL
            continue
        InsulationType = InsulationTypeCell->GetAttributeString("ValueAsString")
        CachedInsulationTypeTable->SetAttributeString(InsulationType, Color)
// If no Insulation Type table table in ResourceSet, Message
else
        Notify("No Piping Insulation type table defined for Piping...")
        else
        Notify("Insulation Type table Name - " +  InsulationTypeTable.Name)
// Build the list of Insulations occurent from the ROOT
    I = 1
    set InsulationList = RootOccurrence->Query("Piping_Insulation_Occurrence", "")
    for I while I <= InsulationList->Size()
        if I > 0 and I <= InsulationList->Size()
            set InsOccurence = InsulationList->GetItem(I)
            if InsOccurence == NULL
                continue
            set InsRef = InsOccurence.Reference
            set GraphicManager = InsOccurence
            continue
        // check if the table contains the value of Insulation Type set on the Insulation Reference
        if CachedInsulationTypeTable->HasAttribute(InsRef.V_InsulationType) == false
            Notify("InsulationType not found" + " - " + InsulationTypeTable.Name + " - " + InsulationTypeColumnIndex + "-" + InsulationType + " - " + ColorColumnIndex + "-" + Color + " - " + CachedInsulationTypeTable.Name)
        // If yes , retreive corresponding color
        else
            GraphicManager.Color = CachedInsulationTypeTable->GetAttributeString(InsRef.V_InsulationType)
            Count = Count + 1
            Notify("InsulationType - " + InsRef.V_InsulationType )
    else
3DXML
Video
USE CASE3 :  Business Rule driven
Need1 : Color pipe when the link with the lineID is created
Coloring tubing, Piping HVAC according Parent LineID information
Remark : an EKL rule to be executed automaticaly in real time. this rule is attached to the Collaborative space through a ResourceSet
The function must be done automatically via Business Rule. Objective is to color object live during the design of the piping network.
To avoid having impact on the overall App performances it could be better to use an Action that user will execute manually instead of using this method
Setup:
Put in place Business Rule (BR) in
  • The resource : “Business Logic for Items”
  • BR “After creation of PPR Link”
This BR is called during each creation of implement links. This is the case when a piping object is attached to a LineID.
So we can use it to controle the associated line to a pipe and set automatically the good color
Video:
Code:
//Notify("ImplementLink Rule")
let lSources(List)
let lTargets(List)
let ustrRelationName(String)
let iRigidPipe(Piping_Rigid_Pipe)
let iLineInst(Piping_Line_Inst)
set lSources = Parameters->GetAttributeObject("Source")
set lTargets = Parameters->GetAttributeObject("Target")
ustrRelationName = Parameters->GetAttributeString("RelationType")
if ((ustrRelationName == "PLM_ImplementLink_Target") and (lSources.Size() > 0) and (lTargets.Size() > 0))
    let sourcePhysicalInstance(VPMInstance)
    let targetLogicalInstance(RFLVPMLogicalInstance)
    set targetLogicalInstance = lTargets[lTargets.Size()]
    set sourcePhysicalInstance = lSources[lSources.Size()]
    if (sourcePhysicalInstance <> NULL and targetLogicalInstance <> NULL)
        let ustrLogicalInstanceName(String)
        let ustrPhycialInstanceName(String)
        ustrLogicalInstanceName= targetLogicalInstance.Name
        ustrPhycialInstanceName= sourcePhysicalInstance.Name
        if(sourcePhysicalInstance.IsSupporting("Piping_Valve_Inst"))
            sourcePhysicalInstance.Name = targetLogicalInstance.Name
        else if(sourcePhysicalInstance.IsSupporting("Piping_Pipe_Inst") AND targetLogicalInstance.IsSupporting("Piping_Line_Inst"))
            set iRigidPipe=sourcePhysicalInstance.Reference
            set iLineInst = targetLogicalInstance
            Notify("Pipe : #, Line ID : #",sourcePhysicalInstance.Name,targetLogicalInstance.Name)
            if(iLineInst.Name == "FFL00001")
                iRigidPipe.SetColor(51,63,255)
            else
                iRigidPipe.SetColor(14,129,40)
        else if(sourcePhysicalInstance.IsSupporting("HVAC_Duct_Inst") AND targetLogicalInstance.IsSupporting("HVAC_Line_Inst"))
            let fexibleDuct (HVAC_Flexible_Duct)
            let rigid_Duct1 (HVAC_Rigid_Duct)
        else if(sourcePhysicalInstance.IsSupporting("Piping_Insulation_Inst") AND targetLogicalInstance.IsSupporting("Piping_Line_Inst"))
            let pipeInsulation (Piping_Insulation)
            set pipeInsulation = sourcePhysicalInstance.Reference
            let prd(Piping_Rigid_Pipe)
            let Opacity(Integer)
            Opacity = 50
            pipeInsulation.SetOpacity(Opacity)
                pipeInsulation.SetColor(51,63,255)
            else
                pipeInsulation.SetColor(14,129,40)
