Context:
Type : 2 Checks
Purpose : Check if the number of clamp along the pipe is enough & check if the maximum distance is respected
Code example
Check if there is enough clamp along the pipe
/* Argument : PipeOcc , Piping_Pipe_Occurence */
Let PipeRef (Piping_Pipe) //pipe reference
let PipeLength (length) // pipe length
Let PartOcc (Piping_Part_Occurrence) // Piping Part occurence attached to the pipe
let PartRef (Piping_PartV1) // Piping Part Reference
let PartSubType(String) // Piping Part PartSubType
let PartList (List) // list of Part attached to the pipe
let NbPartList(Integer) // Nb of part in the PartList
let ClampList (List) // subset of PartList with only Clamp type
let NbClampList (Integer) // Nb of Clamp in the Clamp List
let MaxClampDistance (LENGTH) // Inputs - Max distance between Clamp to be respected
let MinNbOfClampNeeded (Real)
let FinalMessage(String) //final message for the Check
Let i (integer) //counter used for loop
let j (Integer) //counter for List rank
Let CheckStatus (string)
// initialize values
Set MaxClampDistance =300mm
FinalMessage=""
CheckStatus="OK"
i=1
j=1
// Retreive Pipe reference informations - length
PipeRef=PipeOcc.Reference
set PipeLength = PipeRef.V_Length
//Retreive Parts list connected to Pipe
set PartList=PipeOcc.GetRelatedObjects()
NbPartList = PartList.Size()
Notify ( "NbPartList:", NbPartList)
//create a new list that contains only PipingPart with subtype =Clamp
for i while i <= NbPartList
set PartOcc = PartList.GetItem(i)
PartRef=PartOcc.Reference
set PartSubType = PartRef.GetAttributeString("V_SubPartType")
if PartSubType=="Clamp"
ClampList->AddItem(PartOcc,j)
j=j+1
NbClampList = ClampList.Size()
set MinNbOfClampNeeded=PipeLength/MaxClampDistance
Notify ("PipeLength: ", PipeLength)
Notify ( "NbClampList:", NbClampList)
Notify("MaxClampDistance: ",MaxClampDistance)
Notify ("MinNbOfClampNeeded: ", MinNbOfClampNeeded)
If (NbClampList AddTupleSucceededWithComment(FinalMessage,PipeOcc)
Notify ("Final Message OK : " + FinalMessage)
else
ThisCheck->AddTupleFailedWithComment(FinalMessage,PipeOcc)
Notify ("Final Message KO : " + FinalMessage)
Check distance between clamp along the pipe < max length
Let Clamp1Occ (Piping_Part_Occurrence) // Clamp1 occurence attached to the pipe
Let Clamp2Occ (Piping_Part_Occurrence) // next Clamp2 occurence attached to the pipe
let Clamp1Inst (Piping_Part_Inst) // Clamp1 instance attached to the pipe
let Clamp2Inst (Piping_Part_Inst) // Next Clamp2 instance attached to the pipe
let M1 (Matrix) // position matrix of Clamp1 - LocalPosition
let M2 (Matrix) // position matrix of next Clamp2 - LocalPosition
let T1 (Vector) // translation Vector of Clamp1 - LocalPosition
let T2 (Vector) // translation Vector of Clamp2- LocalPosition
let T (Vector) // vector between Clamp1 and Clamp2
let TNorm (Real) // Norme de T : distance between Clamp1 and clamp2
let ClampDist (Length) // Distance between 2 consecutive Clamps
let ClampDistList (List) // List of Clamp distance
let NbClampDistList(Integer) //Nb clamp interval
let ClampDistListKO (List) // output - list of distance tant doesn't respect the Max value
let TextKO (String) // text for the distance that doesn't respect the Max value
let MessageKO (String) // final text for ALL distance that doesn't respect the max value
let ClampInterval (Integer) //count of Clamp interval
let ClampIntervalKO (Integer) //count for Clamp interval that doesn't respect Max distance
TextKO=""
MessageKO=""
FinalMessage=""
CheckStatus="OK"
i=1
j=1
ClampInterval=0
ClampIntervalKO=0
j=j+1
// if there is 0 or only one Clamp check is OK
if NbClampList==0
if PipeLength<=MaxClampDistance
CheckStatus="OK"
FinalMessage="OK , no Clamp & pipe length<=" + MaxClampDistance
else
CheckStatus="KO"
FinalMessage="KO : Clamp missing : No Clamp & pipe length>" + MaxClampDistance
else if NbClampList==1
if PipeLength<=MaxClampDistance*2
CheckStatus="OK"
FinalMessage="OK : only one Clamp & pipe length<= 2x" + MaxClampDistance
else
CheckStatus="KO"
FinalMessage="KO : One Clamp & pipe length> 2x" + MaxClampDistance
else
// Create list of Distances between 2 consecutive clamps rang i & j
i=1
ClampInterval=1
for i while i <= (NbClampList-1)
set Clamp1Occ = ClampList.GetItem(i)
j=i+1
set Clamp2Occ = ClampList.GetItem(j)
Clamp1Inst = Clamp1Occ.Instance
Clamp2Inst = Clamp2Occ.Instance
// Retrive Clamp instance Matrix for 2 consecutive Clamp
M1 = Clamp1Inst.PositionMatrix
M2 = Clamp2Inst.PositionMatrix
// Extract the 4th column to read the translation vector of the position matrix for the 2 clamps
T1=M1.GetColumn( 4 )
T2=M2.GetColumn( 4 )
Notify( "T1=", T1.Dump() )
Notify( "T2=", T2.Dump() )
//compute Vector T between 2 clamps, compute distance = norm de T , set distance in mm
set T=T2-T1
Notify( "T=", T.Dump() )
TNorm=T->Norm()
Notify("TNorm =", TNorm)
ClampDist=TNorm*1mm
Notify("distances = ", ClampDist)
//store distance in list
ClampDistList->AddItem(ClampDist,ClampInterval)
ClampInterval=ClampInterval+1
// KO distance in a list
if ClampDist>MaxClampDistance
CheckStatus="KO"
ClampIntervalKO=ClampIntervalKO+1
ClampDistListKO->AddItem(ClampDist,ClampIntervalKO)
TextKO="KO - Dist Clamp" + i + "To" + j + "=" + ClampDist + ">" + MaxClampDistance + " ; "
Notify("Nb of intervalKO=",ClampIntervalKO)
Notify("TextKO: "+ TextKO)
FinalMessage=FinalMessage + TextKO
Notify("FinalMessage: " + FinalMessage)
If (CheckStatus=="OK")
ThisCheck->AddTupleSucceededWithComment(FinalMessage,PipeOcc)
Notify ("Final Message: " + FinalMessage)
else
}If your clamp are not "Piping part" but "SharedSupport" type :
in the above rules the Clamp is supposed to be a Piping Part Occurence
IF you are using "Support" Object type for Clamp then you must define in the rule the Clamp object as a "SharedSupportPartOccurrence"
--> the above rule must be adjust :
Warning : Today 23x-24xGA this code doesn't work because the function to get Object form PipeOcc "GetRelatedObjects()" doesn't return the "SharedSupportPart" object type --> need to investigate on how to retreive "SharedSupportPartOccurence" from Pipe Occurence
Current code for Piping Part Occ
j=j+1
To be replaced by following :
First , declare the variable for "Support"
Let SupportOcc (SharedSupportPartOccurrence) // Support occurence attached to the pipe
create the list of support per pipe
//create a new list that contains only Support object type
set SupportOcc = PartList.GetItem(i)
ClampList->AddItem(SupportOcc,j)
j=j+1
