EKL - BL to Keep Information on Connected Components
Purpose
Propagate attribute beetween obect when :
  • A component is connected to another component
  • A component is disconnected from another component
  • A connected component is deleted
Datasetup Resource Set :
  • Diagram Resource
Datasetup Resource : Rule to Keep Information on Connected Components
Exemples
from DS Doc : Equipment Connected to Nozzles
The following example, an equipment is connected to two nozzles.
The rule is triggered when connecting the three components.
Notify("Rule Triggered")
Let ThisInstanceObject(RFLVPMLogicalInstance)
set ThisInstanceObject = ThisObject.Instance
Let TargetOccurrence(LogicalOccurrence)
set TargetOccurrence = Parameters.GetAttributeObject("Target_Component_Occ")
Let bOperation(Boolean)
set bOperation = Parameters.GetAttributeBoolean("Connect_Case")
Let TargetInstanceObject(RFLVPMLogicalInstance)
set TargetInstanceObject = TargetOccurrence.Instance
let SourceName(String)
set SourceName = ThisInstanceObject.PLM_ExternalID
let TargetName(String)
set TargetName = TargetInstanceObject.PLM_ExternalID
let SourceDes(String)
set SourceDes = ThisInstanceObject.V_description
let TargetDes(String)
set TargetDes = TargetInstanceObject.V_description
if(bOperation == true )
	if(SourceDes.Length() == 0)
		SourceDes = SourceDes + TargetName
	else
		SourceDes = SourceDes + ";" + TargetName
	if(TargetDes.Length() == 0)
		TargetDes = TargetDes + SourceName
	else
		TargetDes = TargetDes + ";" + SourceName
	Notify("Connect case")
else
	let returnedIndex(integer)
	returnedIndex = SourceDes.Search(TargetName,0,true)
	if(returnedIndex <> -1)
		let SrcResultingStr(String)
		set SrcResultingStr = ReplaceSubText(SourceDes,";" + TargetName,"")
		if(SrcResultingStr == SourceDes)
			let SrcResultingStr1(String)
			SrcResultingStr1 = ReplaceSubText(SourceDes,TargetName+";","")
			if(SrcResultingStr1 == SourceDes)
				let SrcResultingStr2(String)
				SrcResultingStr2 = ReplaceSubText(SourceDes,TargetName,"")
				SourceDes = SrcResultingStr2
			else
				SourceDes = SrcResultingStr1
		else
	returnedIndex = TargetDes.Search(SourceName,0,true)
		let TrgtResultingStr(String)
		set TrgtResultingStr = ReplaceSubText(TargetDes,";"+SourceName,"")
		if(TrgtResultingStr == TargetDes)
			let TrgtResultingStr1(String)
			TrgtResultingStr1 = ReplaceSubText(TargetDes,SourceName+";","")
			if(TrgtResultingStr1 == TargetDes)
				let TrgtResultingStr2(String)
				TrgtResultingStr2 = ReplaceSubText(TargetDes,SourceName,"")
				TargetDes = TrgtResultingStr2
			else
				TargetDes = TrgtResultingStr1
		else
	Notify("Disconnect case")
ThisInstanceObject.SetAttributeString("V_description", SourceDes)
TargetInstanceObject.SetAttributeString("V_description", TargetDes)
The description attributes are updated with the instance names of the connected components.
If the equipment is disconnected from one of the nozzles, the Description attribute is updated.
