EKL - BL to get symbol and graphic attributes
Introduction
Usage : drives the symbol to be used during the placement and also apply graphic properties on the Symbols or routes based on the main and called representations' graphics properties. Main and Called Representations can have different graphic properties
Datasetup Resource Set :
  • Diagram Resource
Datasetup Resource : Rule to get symbol and graphic attributes
Rule Example 1 - Change symbol rep from attribute value
Description
The rule retrieve the value of the V_PredefinedPartType attribute set on the component instance and select the symbol to be displayed with same name
Pre-req and context
this example was made to have an unique Generic logical component for any valve with multiple symbol
the valve symbol to be display is driven by the BL; it can be based :
  • on the Logical Reference Logical Part Subtype attribute
  • or like here on the Logical instance Predefined physical Part subtype
Need to have multiple symbol with names that match with the values in the Part subtype techno table list
Rule
/* ThisObject : LogicalOccurrence */
Let SymbolRep(String)
Let ThisInstance (RFLVPMLogicalInstance)
set ThisInstance = ThisObject.Instance
//Get monitored attribute/attributes
if (ThisInstance.HasAttribute("V_PredefinedPartType") == true )
  SymbolRep = ThisInstance.GetAttributeString("V_PredefinedPartType")
 Parameters->SetAttributeString("Symbol_Name", SymbolRep)
3DXML
Rule Example 2 - Change Symbol Rep id Main or Called
Description
 the rule returns a different symbol name and graphic attributes for main and called representations
  • for MainSymbol : color=0,255,0 ; linethickness=2 ; linetype=1
  • for CalledSymbol : color=255,0,0 ; linethickness=5 ; linetype=3
Pre-req
Component must have 2 different symbols with name = "MainSymbol" and  "CalledSymbol"
Rule
Let sSymbolName(string)
Let LGraphicAttrNames(list)
LGraphicAttrNames.Append("Sch_LineColor")
LGraphicAttrNames.Append("Sch_LineThickness")
LGraphicAttrNames.Append("Sch_LineType")
Let LGraphicAttrValues(list)
Let LRGB(list)
Let bIsMain(Boolean)
set bIsMain = Parameters.GetAttributeBoolean("Is_Main")
if(true == bIsMain)
                set sSymbolName="MainSymbol"
                LRGB.Append(0)
                LRGB.Append(255)
                LRGB.Append(0)
                LGraphicAttrValues.Append(LRGB)
                LGraphicAttrValues.Append(2)
                LGraphicAttrValues.Append(1)
else if(false == bIsMain)
                set sSymbolName="CalledSymbol"
                LRGB.Append(255)
                LRGB.Append(0)
                LRGB.Append(0)
                LGraphicAttrValues.Append(5)
                LGraphicAttrValues.Append(3)
Parameters.SetAttributeString("Symbol_Name", sSymbolName)
Parameters.SetAttributeObject("List_Visualization_Attr_Names", LGraphicAttrNames)
Parameters.SetAttributeObject("List_Visualization_Attr_Values" , LGraphicAttrValues)
Rule Example 3 - Color pipe line according LineID fluid
Description
Set LineType / color / of logical route  .. based on parent LineID Fluid
logical pipe can be attached to a piping LineID or/and a instrument LineID
Pre-Req
Fluid values in the BR must respect the Fluid techno table values
Rule
// ThisObject --> LogicalOccurence
let Inst(Piping_Logical_Pipe_Inst)
let Occ(PipLogicalPipeOcc)
let Ref(Piping_Logical_Pipe)
let LineList(List)
let Line1Name(string)
let Line2Name(string)
let LineOcc(LogicalOccurrence)
let LineRef(RFLVPMLogicalReference)
let LineID1Fluid(String)
let LineID2Fluid(String)
// set Inst=ThisObject.Instance
<strong>set</strong> Occ=ThisObject
<strong>set</strong> Ref=ThisObject.Reference
ListLogicalLineFromMember (Occ,LineList)
<strong>if</strong>(LineList.Size() > 0)
<strong>{<!-- --></strong>
                LineOcc = LineList.GetItem(1)
                <strong>set</strong> LineRef = LineOcc.Reference
                LineID1Fluid=LineRef->GetAttributeString("V_Fluid")
                <strong>}</strong>
// logical pipe is associated to a second lineID like an instrumentLine
<strong>if</strong>(LineList.Size() > 1)
                LineOcc = LineList.GetItem(2)
                LineID2Fluid=LineRef->GetAttributeString("V_Fluid")
                <strong>}</strong>
//Set graphic Properties
<strong>Let</strong> LGraphicAttrNames(list)
<strong>Let</strong> LGraphicAttrValues(list)
<strong>Let</strong> LRGB(list)
// If (Ref->IsASortOf("Piping_Logical_Pipe"))
                <strong>If</strong> (LineID1Fluid=="Cooling Water")
                // Color
                LRGB.Append(0)
                LRGB.Append(0)
                LRGB.Append(255)
                // Thickness
                // Type
                <strong>}</strong>
                <strong>else</strong> <strong>if</strong>(LineID1Fluid=="Hot Water" or LineID2Fluid=="Hot Water")
                // Color
                LRGB.Append(255)
                LRGB.Append(128)
                LRGB.Append(0)
                // Thickness
                // Type
                LGraphicAttrValues.Append(9)
                <strong>}</strong>
                // Color
                LRGB.Append(0)
                LRGB.Append(0)
                LRGB.Append(0)
                // Thickness
                // Type
                <strong>}</strong>
instead of hardcoding the fluid name in the BR , you can modify the Fluid technotable to specify graphic properties in it for Schematic. bellow exemple  done for similar but for 3D coloring
https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/community/swym:prd:R1132100503382:community:6?content=swym:prd:R1132100503382:wikitree:Gvbdu0MFQDSakANT_GH73g
Rule Example 4 - Color Ports if connected or not to pipe/duct
Description
ports on component will be collored in green if it is connected to a logicalpipe or logical Duct ,
if it is not connected it will be in Red
Rule
/* ThisObject = RFLVPMLogicalPort */
let Port(RFLVPMLogicalPort)
set Port = ThisObject
if(Port.IsASortOf("Piping_Logical_Port"))
    /*Port is green if it is considered as a end of a pipe (End1 or End 2)*/
    if((Port.IsASortOf("Piping_Logical_Port_End1")) OR (Port.IsASortOf("Piping_Logical_Port_End2")))
        Parameters -> SetAttributeString("ContourLineColor","0|255|0")
    else
    /*Port is red if it is not considered as a end of a pipe*/
        Parameters -> SetAttributeString("ContourLineColor","255|0|0")
else if(Port.IsASortOf("HVAC_Logical_Port"))
    if((Port.IsASortOf("HVAC_Logical_Port_End1")) OR (Port.IsASortOf("HVAC_Logical_Port_End2")))
    else
