EKL - BL Schematic Callback Route Extremity Modified
Introduction
Usage :
  • provides the opening through Business Rule to the user whenever a route extremity is changed (connected/disconnected) in schematics
  •  allow user to keep routable extremities information through a Business Rule. User may copy the information on some custom attributes.
Datasetup Resource Set :
  • Diagram Resource
Datasetup Resource : Schematic Callback Route Extremity Modified  / Rule to keep route extremities informations
Rule Example 1
Description
In the sample rule below, the instance name of extremities (connected components) is copied on V_description attribute of routable instance like Extremity1Name , Extremity2Name
NULL is copied in case extremity is NULL
Rule
/* Rule created by h66 9/8/2021 */
let RoutableOcc(LogicalOccurrence)
let ListExtrmitiesOcc(LIST)
set RoutableOcc = ThisObject
set ListExtrmitiesOcc = Parameters.GetAttributeObject("List_Extremities_Components")
let RoutableIns(RFLVPMLogicalInstance)
set RoutableIns = RoutableOcc.Instance
Let String_Description(String)
Set String_Description = ""
Let i = 1
Let isize = 0
set isize = ListExtrmitiesOcc->Size()
​​​​​​​let ExtremityOcc(LogicalOccurrence)
if(NULL <> RoutableIns)
  for i while i<=isize
    set ExtremityOcc = ListExtrmitiesOcc->GetItem(i)
    if(NULL <> ExtremityOcc)
      Let InstanceObject(RFLVPMLogicalInstance)
      set InstanceObject = ExtremityOcc.Instance
                Let InstanceName(String)
      set InstanceName = InstanceObject.PLM_ExternalID
      if (i == isize)
                  set String_Description = String_Description + InstanceName
      else
                  set String_Description = String_Description + InstanceName + ", "
    else
      if (i == isize)
                   set String_Description = String_Description + "NULL"
      else
                  set String_Description = String_Description + "NULL, "
  RoutableIns.SetAttributeString("V_description",String_Description)
3DXML
Rule Example 2
Description
In the sample rule below, the Operating pressure of the Route PArent LineID  is copied on V_description attribute of the connected Equipment
limitation, when disconnecting route the value on Equipment is not reset
Rule
//Operating pressure of the route parent line ID is copy on conencted component instance description only for "Tank"
//Retreive info from Pipe parent lineID
let ParentLineID(Piping_Line_Inst)
let ParentLineIDRef(Piping_Line)
let LineIDList(List)
ListLogicalLineFromMember(ThisObject,LineIDList)
ParentLineID=LineIDList->GetItem(1)
set ParentLineIDRef=ParentLineID.Reference
let OpPressureReal(Real)
let OpPressure(String)
set OpPressureReal=ParentLineIDRef.GetAttributeReal("V_OperatingPressure")
set OpPressure=ToString(OpPressureReal)
// pipe Extremities
Let String_Description(String) // pipe instance description
Let ExtremityInst(RFLVPMLogicalInstance)
let ExtremityRef(RFLVPMLogicalReference)
let ExtremityInstDesc(String)
let ExtremityInstDescNew(String)
Let InstanceName(String) //connected object Extremity instanceName
let EQTSubtype (string)
Set ExtremityInstDescNew=""
Let i = 1
Let isize = 0
 Notify ("BR_Propagate Att Pipe<->Component")
   set ExtremityInst = ExtremityOcc.Instance
   set ExtremityRef=ExtremityInst.Reference
   set ExtremityInstDesc=ExtremityInst.GetAttributeString("V_description")
   set EQTSubtype=ExtremityRef.GetAttributeString("V_Ens_SubType")
   //Notify("ConnectedCompSubtype: ",EQTSubtype)
   set InstanceName = ExtremityInst.PLM_ExternalID
       if (i == isize)
           If((ExtremityRef->IsASortOf("EnsLogicalEquipment")) and (EQTSubtype=="Tank"))
                  set ExtremityInstDescNew = ExtremityInstDesc + OpPressure
       else
                  set ExtremityInstDescNew = ExtremityInstDesc + OpPressure + ", "
   else
     if (i == isize)
       //If((ExtremityRef->IsASortOf("EnsLogicalEquipment")) and (EQTSubtype=="Tank"))
              set ExtremityInstDescNew = ExtremityInstDesc + "NULL"
     else
              set ExtremityInstDescNew = ExtremityInstDesc + "NULL, "
   ExtremityInst.SetAttributeString("V_description",ExtremityInstDescNew)
