Introduction
Usage : when using Manipulate command, with option Business Rule to copy a portion of the schema.
You will define in the Rules if you want to duplicate the objects or instantiate them according there type and subPartype
Datasetup Resource Set :
- Diagram Resource
Datasetup Resource : Rule for instantiate/duplicate option
Rule Example1 - Copy a set of object inside the same P&ID sheet/view
Description
Only Equipment object will be duplicated, all others (pipes, branches, valves, ...) will be instantiated
rule
/*/* CATRule signature: (ThisObject : #In LogicalOccurrence, Parameters : #In RuleContext) : #Void */
/* Sample rule*/
/* Input parameter is List of PLM Occurrences*/
/* Output parameter is List of integers, which is one to one mapping with List Of PLM Occurrences*/
/* In this sample rule, we fill 2 in output list for Equipments and 1 for all other objects*/
/* all objects are reinstantiated into the targeted system */
Object manipulation:
1: The object is instantiated.
2: The object is duplicated.
3: The object is placed in view.
Context for new instances:
0: The context for new instance is the same as the existing instance.
1: The context for new instance is different from the existing object. It will be the logical father of the sheet containing the duplicated view.
/* Input parameters read */
let This2DObject (LogicalOccurrence)
let ListPLMOccurrences(LIST)
set ListPLMOccurrences = Parameters.GetAttributeObject ("List_PLM_Occurrences")
let OutputInsDupOptionsList(List)
let OutputContextChangeOptionsList(List)
Let ReferenceObject(RFLVPMLogicalReference)
let OccurrenceObject (LogicalOccurrence)
let sDiscipline (String)
Let j = 1
for j while j<=ListPLMOccurrences->Size()
set OccurrenceObject = ListPLMOccurrences->GetItem(j)
set ReferenceObject = OccurrenceObject.Reference
sDiscipline = ReferenceObject.V_discipline
if(sDiscipline == "EnsLogicalEquipment")
OutputInsDupOptionsList.Append(2)
OutputContextChangeOptionsList.Append(1)
else
OutputInsDupOptionsList.Append(1)
j = j+1
Parameters.SetAttributeObject("List_Instantiate_Duplicate_Options", OutputInsDupOptionsList)
Parameters.SetAttributeObject("List_Context_Change_Options", OutputContextChangeOptionsList)
Rule Example2 - Copy a set of object inside another P&ID sheet/view
video:
code:
