Introduction
Purpose : Create and modify 3D Flexible pipe
Availability : 25xFD02
- EKL for Flexible Pipe/Duct
- Add 3D Point , Get Node Type, Remove Node, Get/Set Build Algorithm, wGet/Set Build Mode, Get/Set Global Slack, Get/Set Length, Get/Set Minimum Bend Radius, Get/Set Local Slice Mode, Get/Set Local Slice Value, Update existing flexible pipe properties from a raw material or reference flexible pipe
- EKL for Rigid Pipe / duct / tray
- Update existing Rigid pipe properties from a raw material.
Examples
Add 3d points in flexible route
- input parameter : FlexiblePipeRef -> Piping_Flexible_Pipe
let pBody(BodyFeature)
let pPoint(Point)
let NewPoint(Point)
let pGSMPoint(GSMPoint)
let pGSMPointCoord(GSMPointCoord)
let ListPoints(list)
let pPointType(PointType)
let NodeIndex(Integer)
let retCode(Integer)
let Validation(Boolean)
Validation = false
if(NULL <> FlexiblePipeRef)
//Add3DPoint
// create point
pBody = FlexiblePipeRef ->Find ("BodyFeature","",TRUE)
if (NULL <> pBody)
Trace (1, " Body retrieves : ",pBody.Name)
SetWorkingContext(pBody)
// Point_Test1
NewPoint = new("Point", "Point_Test1", pBody)
pPointType = "Coordinates"
set pGSMPoint = NewPoint
if (NULL <> pGSMPoint)
pGSMPoint.PointType = pPointType
set pGSMPointCoord = pGSMPoint
pGSMPointCoord.X = 100mm
pGSMPointCoord.Y = 200mm
pGSMPointCoord.Z = 300mm
pGSMPointCoord.Update()
Trace (1, " Body retrieves : ",NewPoint.Name)
ListPoints.Append(pGSMPoint)
//Point_Test2
NewPoint = new("Point", "Point_Test2", pBody)
pGSMPointCoord.Y = 300mm
Trace(1, " Body retrieves : ",NewPoint.Name)
set NodeIndex = 0
set retCode = FlexiblePipeRef.Add3DPoint (ListPoints, NodeIndex)
if(0 == retCode)
Validation = true
Trace (1, "======Add3DPoint done successfullyh=======")
else
Validation = false
Trace (1, "======Add3DPoint FAILED=======")
Find node point type pipe and remove node point of flexible pipe
let NodeType(PipingNodeType)
let NodeIndexToRemove(Integer)
let ListNodeIndexToRemove(List)
let oReferenceBendRadius(Length)
NodeIndex = 2
// Get Node Type
FlexiblePipeRef -> GetNodeType(NodeIndex, NodeType)
Message ("Node 2 Type:", NodeType)
// Remove Nodes
NodeIndexToRemove = 2
ListNodeIndexToRemove.Append(NodeIndexToRemove)
NodeIndexToRemove = 3
FlexiblePipeRef -> RemoveNode(ListNodeIndexToRemove)
Message ("Removed Nodes:", ListNodeIndexToRemove)
Find build algorithm and build mode for flexible pipe and also user should set/change build algorithm and build mode for flexible pipe.
let iBuildAlgo(CATEbm_BranchTypeEnum)
let oBuildAlgo(CATEbm_BranchTypeEnum)
let iBuildMode(CATEbm_FlexBuildModeEnum)
let oBuildMode(CATEbm_FlexBuildModeEnum)
// Build Algorithm
// Set Build Algorithm
iBuildAlgo = "CATEbm_FlexCurveFLX"
FlexiblePipeRef -> SetBuildAlgorithm(iBuildAlgo)
Message ("Set Build Algorithm: ", iBuildAlgo)
// Get Build Algorithm
FlexiblePipeRef -> GetBuildAlgorithm(oBuildAlgo)
Message ("Get Build Algorithm: ", oBuildAlgo)
// Build Mode
// Set Build Mode
iBuildMode = "CATEbm_BMLength"
FlexiblePipeRef->SetBuildMode(iBuildMode)
Message ("Set Build Mode: ", iBuildMode)
// Get Build Mode
FlexiblePipeRef->GetBuildMode(oBuildMode)
Message ("Get Build Mode: ", oBuildMode)
Set and get of global slack for flexible pipe
let iGlobalSlack(Real)
let oGlobalSlack(Real)
// Global Slack
// Get Global Slack
FlexiblePipeRef -> GetGlobalSlack(oGlobalSlack)
Message ("Get Global Slack: ", oGlobalSlack)
// Set Global Slack
set iGlobalSlack = 10
FlexiblePipeRef -> SetGlobalSlack(iGlobalSlack)
Message ("Set Global Slack: ", iGlobalSlack)
Set and get of length for flexible pipe
let iLength(Length)
let oLength(Length)
// Length
// Get Length
FlexiblePipeRef -> GetLength(oLength)
Message ("Get Length: ", oLength)
// Set Length
set iLength = 2000mm
FlexiblePipeRef -> SetLength(iLength)
Message ("Set Length: ", iLength)
set and get of minimum bend radius for flexible pipe
let iMinBendRadius(Length)
let oMinBendRadius(Length)
// Minimun Bend Radius
// Get Minimun Bend Radius
FlexiblePipeRef -> GetMinimumBendRadius(oMinBendRadius)
Message ("Get Length: ", oMinBendRadius)
// Set Minimun Bend Radius
set iMinBendRadius = 20mm
FlexiblePipeRef -> SetMinimumBendRadius(iMinBendRadius)
Message ("Set Length: ", iMinBendRadius)
set and get of local slice mode for flexible pipe
let iLocalSliceMode(CATEbm_SlackAndLengthModeEnum)
let oLocalSliceMode(CATEbm_SlackAndLengthModeEnum)
let Index(Integer)
set Index = 2
// Local Slice Mode
// Get Local Slice Mode
FlexiblePipeRef -> GetLocalSliceMode(Index, oLocalSliceMode)
Message ("Get Length: ", oLocalSliceMode)
// Set Local Slice Mode
iLocalSliceMode = "IgnoreSlack"
FlexiblePipeRef -> SetLocalSliceMode(Index, iLocalSliceMode)
Message ("Set Length: ", iLocalSliceMode)
set and get of local slice value for flexible pipe
let iLocalSliceValue(Length)
let oLocalSliceValue(Length)
let Index(Integer)
set Index = 2
// Local Slice Value
// Get Local Slice Value
FlexiblePipeRef -> GetLocalSliceValue(Index, oLocalSliceValue)
Message ("Get Length: ", oLocalSliceValue)
// Set Local Slice Value
iLocalSliceValue = 100mm
FlexiblePipeRef -> SetLocalSliceValue(Index, iLocalSliceValue)
Message ("Set Length: ", iLocalSliceValue)
Update existing flexible route properties from a raw material or flexible reference route.
- A link is created between pipe and raw material and material name is copied from raw material to pipe.Explain the objectives of this test.
- Update existing flexible route properties from reference flexible route
// Update existing flexible route properties from reference flexible route
let ExistingPipeInst(Piping_Flexible_Pipe_Inst)
let ExistingPipeRef(Piping_Flexible_Pipe)
let ExistingPipeVPMRef(VPMReference)
let PipeInst(Piping_Flexible_Pipe_Inst)
// Step 1 : Retrieve the Flexible pipe Reference
set ExistingPipeInst = ReferenceRigidPipeInst
set PipeInst = TargetRigidPipeInst
if(NULL <> ExistingPipeInst)
set ExistingPipeRef= ExistingPipeInst.Reference
if(NULL <> PipeInst AND NULL <> ExistingPipeRef)
// Step 2 : SetNewRefrence
// Existing Reference sent
set ExistingPipeVPMRef = ExistingPipeRef
if(NULL <> ExistingPipeVPMRef)
set retCode = PipeInst.SetNewReference(ExistingPipeVPMRef)
if(0 == retCode)
Message ("Set New Reference: ", PipeInst.Name)
Update existing flexible route properties from raw material
//Update existing flexible route properties from raw material
let RawMaterial(Raw_Material_PipeTube)
let myQuery(PLMQuery)
let results(List)
let currentResult(PLMQueryResult)
let RawMaterialVPMReference(VPMReference)
// Step 1 : Retrive Raw Material from database
myQuery = CreatePLMQuery("Raw_Material_PipeTube")
myQuery->AddCriterion("V_Name","Rigid Raw Material PipeTube")
results = myQuery->RunQuery()
currentResult = results[1]
if(currentResult<>NULL)
set RawMaterial = currentResult->LoadResult()
set RawMaterialVPMReference = RawMaterial
PipeInst = TargetFlexiblePipeInst
if(NULL <> PipeInst AND NULL <> RawMaterialVPMReference)
// Step 2 : Set New Reference
set retCode = PipeInst.SetNewReference(RawMaterialVPMReference)
if(0 == retCode)
Message("Set New Reference :", PipeInst.Name)
