Get Reverse Engineer role, enriched with toolset for mechanical, styling & experience design, to secure accurate product re-design and prototyping, for any process workflow between real and virtual worlds
Virtual & Real Reconstruction Designer offers a comprehensive toolset of styling surfaces, mechanical & human design, plus full rendering & VR capabilities.
Able to process even large data sets, the role allows full geometrical reconstruction with best class B quality in an optimized time frame (ignoring fillet/chamfers, or not).
Resulting shapes can be set to various level of abstraction (surface or solid, part or product) depending on targeted process. Various worklflows allow to validate results against several criteria:
data abstraction vs targeted usage (surface / solid, sharp edge/fillets...)
best experience compromise vs. prototype accuracy,
part dimensioning control,
compensated shape computation,
surface quality check through high-end visualization & offsetability treshold
Benefits
For reconstruction from scan,ccelerate the workflow from 1 day to 1 hour for Class B Surfaces.
Upgrade virtual model up to final accurate product, ready for detailled prototyping
Benefit from VR, rendering & Human design to check virtual prototype experience first, and minimize physical iterations cost.
Highlights
Import, check, repair and optimize scanned data, even large cloud (billions of points)
Reconstruct exact geometry from any scan data or polygon modeling through semi-automatic tools
Compare the virtual Model with scanned prototype to check consistency and assess dimension validity
Immersive and Collaborative Experience for better perception of Virtual model
Main toolset for advanced surface design (including subdivision surfaces), mechanical design (solid & assembly design), and high-end rendering
Prepare virtual model for 3DPrinting, filter model IP before supplying tasks, pre-validate experience with Human Design.
Calculate compensated shape to absorb deforming pheneomenon (from simulation or actual measured results)
