Model, simulate and anlyze of the flight dynamic characteristics of a wide range of flight vehicles
The Modelica based Systems Flight Dynamics Library enables the rapid modeling, simulation and analysis of the flight dynamic characteristics of a wide range of flight vehicles. The environment models provide functionalities to cover on-ground operations up to flight at high speeds and high altitudes. The library is ideally suited for design analysis in various fields and stages of the aircraft development process, multi-disciplinary development of accurate flight control laws as well as for use in real-time flight simulators for commercial and military aircraft, unmanned aerial vehicles (UAVs), airships and rotorcraft. Library contains FASER and RCAM aircraft simulation models as examples for reference.
Benefits
Create accurate multi-disciplinary models and simulation of aircraft flight dynamics that span on-ground operations through to high speed and high attitude flights
Assess the impact of aircraft configuration changes on flight characteristics early in the design process
Leverage accurate flight dynamic models and realistic visualization to create real-time simulators for training pilots and product marketing
Library to model the environment of an aircraft (gravity, atmosphere, wind, terrain, ...)
True multi-disciplinary modeling and simulation of aircraft flight dynamics
Supports simulation from on-ground operations through to high speed and high altitude flights
Reference examples are available to understand how to configure aircraft simulation models.
Highlights
Develop and interconnect airframe and systems models
Model complexity can be easily scaled to enable analysis and simulation at any stage of the design process
Improved model maintenance through the use of a single tool for modeling, control and simulation
Ability to integrate with a wide range of other compatible Modelica libraries
Import & integrate Simulink models
Full Functional Mockup Interface (FMI) support
