Rapidly design and validate DC and high-frequency AC electrical network with multi-level of detail
The Electric Power Systems library enables to rapidly design and validate electrical power systems, comprising DC and AC high frequency (800Hz) distribution architecture with real time capabilities. This applies for energy balance architecture studies, transient studies, thermal management and coupling with cooling. Moreover, failure investigation can be performed with Fault triggering and re-configuration for fail safe/fail active architectures.
The EPSL covers the key components of an electrical power system at different levels of detail. The architectural level corresponds to "simple" phasor theory resulting in a quasi-static description of the system. The functional level of detail uses dynamic phasors to cover dynamic effects in the models. The level of detail can be selected via parameters in the components.
Additionally the EPSL enables the description of harmonics of the fundamental AC frequency, which can be either constant or variable. Currently the AC components are either single or three-phased, whereas other phase numbers would be straight-forward to be added due to the generic modeling approach of components.
Benefits
Efficient control design and validation of the distribution architectures
Performant execution, real time capabilities for efficient control design and validation of the distribution architectures and flight simulators
Enable the concurrent cooling system design with thermal loss and dissipation of the components
This library is implemented based on phasors.
This helps in very fast computation
No dynamics in steady state
Usual description for electric quantities in power system design
It enables steady state initialization
Simple computation of RMS value and phase
This library provides interfaces to thermal domain for loss estimation.
Highlights
Design and validate aircraft electrical power systems, comprising DC and AC high frequency (800Hz) distribution architectures
Real-time simulation
Contain components: Sources, Electrical loads, Semiconductors, Transformer and Rectifier, Lines, Sensors
Example of reference architecture to easily asses industrial use cases
Streamlined process along the architecture definition
Architectural level: steady state studies, based on phasor
Functional level Transient studies based on dynamic phasor
Easy to switch from steady state to transient studies with propagation of parameters without having to re-create the models
