Optimize development cost for complex structural assemblies by easy evaluation of alternative “What If” design scenarios and managing smooth transition from basic to detail design
Steel Structure Designer role enables to perform fast and productive functional design with detail design information. And it captures manufacturing intents into detail design so that user prepares manufacturing process. Also Steel Structure Designer is intent on steel structure design and component/equipment positioning. It supports to specific template definition (standard component and contextual component) to perform easy and fast arrangement of equipment and component through its own intelligent positioning functionality. Also, this role has capability to design foundation efficiently for heavy equipment and component.
Enable productive full parametric preliminary design to perform analysis with early cost & material estimations
Generate fast and easy detail design from preliminary design
Enable to make precise and accurate detail design for complex frame structures with tight and seamless integration with manufacturing
Engineer the steel layout design for ladders, stairs, and auxiliary steel systems
Design steel structure for equipment support
Design steel structure connection for steel structural elements
Define foundations for non-discipline specific equipment as necessary
Integrated knowledge rules to insure compliance with required design standards and regulations
Benefits
Support full parametric design with various construction elements
Perform early estimation of preliminary design for manufacturing planning in advance
Experience robust and flexible detail design piece parts generation from basic design by capturing detail design specification in basic design
Perform productive design without errors and rework, also provide realistic geometrical result in detail design for better completeness of design
Support tight and seamless integration with manufacturing also collaborate well with other disciplines such as Initial Design, Simulation, and Weight and Balance
Generate various classification drawings and production drawings with symbolic and mechanical representations
Enable intelligent arrangement of the equipment and component in different positioning context
Perform efficient way to define and instantiate template
Enable to define dedicated PLM Objects for detail design and equipment system
Highlights
Allow to design on top of User Defined Reference Geometry and Space Referential Geometry
Provide more intuitive user interfaces in detail design
Capture detail specification with simplified representation in preliminary design
Synchronize from basic design to detail design productively in interactive way and batch process
Support AEC compliant Types for PLM object in detail design
Support efficient way to instantiate and positioning the components and templates
Enable to design functional and detail outfitting system including equipment foundation
Enable to design detail & complex steel connection model
