Reverse Engineer is a specific and dedicated role for any user dealing with any workflow involving some transition between digital and physical worlds.
Reverse Engineer is the best in class reconstruction tool on the market, addressing worflows between phyiscal and virtual worlds, including simulation results & prototyping needs
Reverse Engineer addresses the transitions between digital and physical worlds by:
import, generation, modification and optimization of digitized data like meshes or scans .
manage, repair, refine modify, improve & remodel scan & mesh data provide various semi-automatic tools to rebuild exact geometry
quickly export 3D data to 3D printable filesadjust a shape from a displacement field to compensate dilatation or spring-back effects.
assess validity of a produced part by comparing its measured vrsion (scan) with its digital perfect twin (reference specifications)
Benefits
Be provided with semi-automatic tools to rebuild exact geometry from any scan data or polygon modeling, with best quality at 1st shot
Compare digitized model and annotated dimensions of CAD data to control and assess the part's validity
Deform master reference data to compute the compensated shape from a displacements field (measured or simulated)
Check data validity for 3D Printing and export 3D to STL or AMF formats
Highlights
Manage, repair, refine, modify, improve scan & mesh data
Remodel exact geometry with semi-automatic tools
Generate STL files from exact geometry for 3D printing
Quickly obtain through global deformation the compensated shape able to absorb deforming physical phenomenon's.
On-premise or On-The-Cloud
