Accelerate the Hydroformed Sheetmetal part design with respect to manufacturing rules, in context of an Airframe assembly including model based definition.
Hydroformed Airframe Designer role allows to design Airframe particularly focusing on the cost-effective Hydroformed sheet metal process, while adopting a full Model Based Design approach.
All sheet metal specifications are captured to build a corporate knowledge-based automation to increase the quality of the designs. All company-defined standards tables are made available to the designer to increase the design standardization and reduce the manufacturing cost. Thanks to the complete integration within the 3DEXPERIENCE Platform, it is possible to share modifications real-time and work concurrently in teams on the same product.
The role covers the most comprehensive processes, including high-quality surface & part design, assembly creation, mechanism motion, 3D mock-up review, tolerances and annotations creation in 3D and drawing generation. The full product manufacturing information is conveyed with complete product definition through 3D annotations. The dedicated drawing capability includes unfolded view aling with some specific settings making manufacturing preparation very easy for supply chain collaboration.
Benefits
Cuts tooling design cost thanks to dedicated manufacturing preparation functions
Reduces design and manufacturing errors thanks to process oriented sheet metal features
Leverage Model Based Design through fast 3D Tolerancing adoption
Accelerate productivity based on automatic generation of the Functional Tolerancing, with quality in accordance to standards, Traceability and Standardization
Cuts design modifications capitalizing IP and applying automated design and check rules
Reduces Decision Times using concurrent engineering delivered by the single platform
Avoid repititive taks by re-using existing design assets
Increase the number of studies for complex mechanism design and motion alternatives on large assemblies with flexibility
Reduce errors of tolerancing and drawing interpretation.
Improve automation in downstream application and update stability for engraving definition based on associative text creation in sketcher
Complete Product definition throughout easily readable 3D Annotations with optimized layout conveying full Product Manufacturing Information.
Highlights
Associative and dedicated hydroformed sheet metal feature-based modeling in context of an Airframe assembly
Real-time concurrent engineering between the unfolded or folded 3D shape representations
Access to company-defined standards tables and capture corporate knowledge, increases the quality of designs
The Semantic Tolerancing Advisor guides the designer to be compliant with standards such as ISO, ANSI/ASME and JIS.
Perform detailed Product review to detect and track interferences, check the weight distribution and analyze the digital mock-up with relevant engineering data
Capitalize on your assets, capture modeling methodologies and reuse associative templates with Knowledge based design automation
Dedicated drawing capability including unfolded view with specific settings, generating associative layouts with multi-views, dimensions, and associated bill of materials
Improved Natural Shape features with parametric modeling for smarter and adaptive models
Seamlessly insert components into designs from PartSupply
Easily readable 3D Annotations with optimized layout in 2D Layout & Drafting from 3D Product Template Definition
