CATIA - ENOVIAvpm Supply Chain Engineering Exchange 1 (EW1) allows a sub-contractor to load up and work on a CATIA work package extracted by the OEM from its ENOVIA context.
Product Overview
CATIA -ENOVIAvpm Supply Chain Engineering Exchange 2 - (EWE) supports the ability to Export/Import CATIA V5 product data and associated CATIA V5 links from the OEM site to the subcontractor site, which is disconnected from the OEM ENOVIA database. CATIA - ENOVIAvpm Supply Chain Engineering Exchange 1 - (EW1) is the P1 product used by subcontractor to recover a V5 session from OEM mobile files and then make demanded changes.
Thanks to CATIA - ENOVIAvpm Supply Chain Engineering Exchange 2 - (EWE), the OEM defines a work context in ENOVIA VPM V4 or V5 and loads all associated data in CATIA V5. Then the OEM generates mobile files and provides them to the supplier. Afterwards, the supplier, thanks to CATIA - ENOVIAvpm Supply Chain Engineering Exchange 1 - (EW1), makes all data modification or creation requested by the OEM and sends back updated mobile files. Finally, the OEM loads data provided by the supplier in CATIA V5 and imports them in ENOVIA VPM V4 or V5 with CATIA - ENOVIAvpm Supply Chain Engineering Exchange 2 - (EWE). CATIA - ENOVIAvpm Supply Chain Engineering Exchange 1 is dedicated to extracting a work package from ENOVIAVPM and ENOVIA V5 VPM and re-integrating it through a reconciliator tool. After extraction from ENOVIA, CATIA - ENOVIAvpm Supply Chain Engineering Exchange1 is required to read and edit the extracted work package in the CATIA environment.
Only data extracted using CATIA - ENOVIAvpm Supply Chain Engineering Exchange 1 and edited with this product or new data can be re-integrated into ENOVIAVPM or ENOVIA V5. VPM.
Product Highlights
Read mobile files
Change, create CATIA V5 objects and save modifications in mobile files
Product Key Customer Benefits
Read mobile files... The subcontractor who uses EW1 can open and load CATIA V5 session that has been built by its OEM.
Change, create CATIA V5 objects and save modifications in mobile files ... When the user has finished his job, he can save his final modifications into his mobile file, and then send it to his OEM to achieve reconciliation with his OEM ENOVIA database.
