CATIA - Core & Cavity Design 2 (CCV)
Create associative definitions of the core and cavity of a mold and assesses part moldability, tool feasibility and the detailed mechanical design of core and cavity plates.
Product Overview
CATIA - Core & Cavity Design 2 (CCV) allows rapid and cost effective design of the core and cavity used in mold tooling or manufacturing equipments. This products provides a fast splitting tool that takes a surfacic or solid part and separates it into core and cavity with sliders and loose cores.
CATIA - Core & Cavity Design 2 (CCV) is a stand-alone product that determines the ability of a component to be manufactured thanks to technological criteria (Moldability). This product allows also the user to fill up technological holes within the core and cavity surfaces, identify the parting lines and to generate the parting surfaces.
Product Highlights
CATIA - Core & Cavity Design 2 (CCV) products offers the following main functions:
Core & Cavity Separation workbench:
Import of the Molded Part (Skrinkage operation during the Import operation)
Direction management (Add Main Pulling direction, Add Slider direction, Add Axis system)
Mold area management (Move faces from a Mold area to an other, Split faces, Add Faces in a Mold area)
Extract Parting Line
Reflect Line
Reference Element (Point, Line, Plane)
Full Design capabilities for Core & Cavity process
New standard design capabilities in the workbench to make the product self-contained to enable preparation of part for moldability and Core & Cavity design
- Text with Leader
- Flag Note
- Measure
- Power-Copy
Draft extract :
Main pulling direction definition based on Draft analysis of the Molded Part
Exploded view of the different area : new visualization mode that allows user to separate skins according to their pulling directions (red and green skins). This is a visual method to enhance readability of the moldability of the part.
Slider Direction definition based on draft analysis on a given mold area
Assisted extraction of the Mold areas
Associativity in the definition of the main pulling direction
- Core & Cavity and undercuts areas are recomputed when you modify the input of main pulling direction
Management of a Mold area :
Transfer of faces from one area to another.
Split of faces into an area
Parting line definition
Product Key Customer Benefits
Import of Part design data (solid or surfacic) and scaling application... User is able to use any Design Part that is a solid or a volume created with CATIA or any other system. The part is positioned into local current avis system that can be created from : the existing local axis system of the design Part if it exists, the bounding of the Part, the gravity center of the Part or even user coordinates. To take in account the shrinkage during molding operation, user has the ability to apply affinity or scaling.
Main pulling direction definition... Based on draft analysis criteria, this tool is used to identify Core & Cavity and undercuts area. Compass is used to define easily and interactively the right pulling direction. The Part is automatically divided in 3 sets, related to the selected associative pulling direction. So that, Core & Cavity and undercuts areas are recomputed when you modify the input of main pulling direction. User can easily spot the divided parts due to the following color mapping : green faces can be unmolded, red faces can be unmolded in the opposite direction and blue faces need to be part of slider, loose core or to be splitted.
Slider Pulling Direction definition... Based on draft analysis criteria, this tool enables designers to identify slider surface from the previously identified undercuts area. Compass is used to define easily and interactively the right slider direction. The Part is automatically divided in 2 sets. The green faces can be unmolded in the slider direction and the blue one need to be part of an other slide, loose core or to be splitted.
Molding areas detailing... Designer can use Cut, Copy, Paste and Split of faces from a molded area to an other one. Advanced tool helps the user to perform several operations in one step. For instance, Cut and Paste of faces from a molding area to an other can be achieved in a single operation. User can also split an area and distribute the result in the molding areas.
