Adapt incompatible dimension parent with wire sub-element
In this section, you will explore a use case demonstrating the Adapt incompatible dimension parent with wire sub-element update strategy.
This technical practice highlights the strategy which adapts the input locally when a feature is in error. Its ensure the feature maintains the correct connectivity.
A designer working in generative shape design avoids working with multi-domain as it requires more efforts to make it useful. Specifically, when working with a feature whose references are derived from the intersection of a wire-frame feature. It could be a point, line, curve segment or even a surface.
This technical practice highlights the 3DShape update strategy known as Adapt incompatible dimension parent with wire sub-element used in Resilient modelling. When a feature is in error because of a geometric change in one of its inputs, the feature adapts the input locally instead of failing and provides the expected output.
All roles that include the Part Design app, Part Design Plus app, Generative Shape Design app and Generative Shape Design Plus app
Mechanical Designers, Conceptual Designers, Mechanical Surface Designers
You can choose to extract the Start, Middle, or End point of the wire result. Select this option to compute a point result from an input wire. Line feature provides better result with this strategy.
Use Case : Execute the Adapt incompatible dimension parent with wire sub-element strategy when a parent feature cause error in a child feature.
Scenario: Let us consider a case where a surface is created from a line, and the line is defined using a Point onCurve feature. Now, the curve on which the point is created is positioned at an angle to a reference line. When you change this angle, for certain values of the angle, the geometry becomes invalid, causing the surface to fail.
Play the video to watch how to use the Adapt incompatible dimension parent with wire sub-element update strategy for wire elements.
To learn more about Adapt incompatible dimension parent with wire sub-element, explore the M3S learning module.
