2023x GA [CATIA] Stiffened Structure Engineer
Create, Validate and quickly Converge Concept Stiffened Structure made of Composites Materials
1. Fast definition of stiffener positions on a panel and easy definition of iso-thickness zones of composite materials on a skin
2. Finite Element model setup with Structural simulation and Design exploration capabilities with embedded compute (4 cores)
3. Model reduction into beam elements for a faster convergence of the sizing process
4. Data continuity across conceptual, preliminary design and detailed design phases
What's new in the Stiffened Structure Engineer role in 2023x release
Quick Grid command: The wing panel is divided into regions with easy-to-use on the fly geometry creation
Quick Grid command: Composites materials are used for this concept: laminate definition is assigned to the wing surface
View of the finite element model mesh and Review of the materials applied to the regions of the wing surface (ply stack plot)
Simulation results of the Structural Analysis performed on the model meshed with shell elements
Quick Grid command: Laminates are applied on regions of the surfaces of the components of the structure (wind turbine blade)
The whole blade design is reduced into a 1D beam equivalent model thanks to idealization techniques provided in the Stiffened Structure concept app
Each beam element is automatically assigned with the equivalent stiffness of the cross-section
Loads and boundary conditions are applied to the idealized 1D beam model
Simulation results of the Structural Analysis performed on the model idealized with 1D Beam elements
