🎓 Success Path: Requirements Simulation Engineer (STIMULUS)
STIMULUS Requirements Simulation Engineer
STIMULUS Requirements Simulation Engineer role enables system architects to simulate requirements and to detect ambiguous, incorrect, missing, or conflicting requirements before the design begins, thus creating the high-quality specifications needed for the validation of safety-critical embedded systems. Development teams spend less time redefining requirements, rewriting, and re-debugging code, resulting in fewer development iterations needed to achieve quality results.
At validation phase, this role also enables test engineers to generate test vectors and test objectives automatically and to check that your embedded code complies with its specification.
Testing teams no longer write nor maintain test cases that are manually derived from the requirements. Instead, they reuse work done by system architects to build highly flexible test campaigns, allowing to adopt effective agile methods
🧑‍🤝‍🧑 Your profile
You want to Make Embedded Systems Requirements Right The First Time.
You want to Extend Model-Based Systems Engineering with Requirements-In-the-Loop Simulation.
⌚ Estimated time
Onboarding: 4h40
🧑‍🏫 Your learning path starts here
Practice STIMULUS Requirements Simulation Engineer
In this module, you will learn how to use STIMULUS to edit, debug, and test requirements to ensure that the specifications are correct, consistent, and complete all during the specification stage.
<strong>Key concepts covered:</strong>
📌 Discover STIMULUS as a requirements simulation tool
📌 Create, edit, and Debug Requirements
📌 Simulate Requirements
📌 Perform Co-Simulation in and outside STIMULUS environment
📌 Connect STIMULUS to the <strong>3D</strong>EXPERIENCE platform
STIMULUS Requirements Simulation Engineer - Associate
This certification validates your knowledge and skills on the Requirements Simulation Engineer role within the STIMULUS software. You will be asked multiple-choice questions (MCQ) on system architect capabilities, requirement edition, requirement validation and co-simulation.
Tutorials on STIMULUS for beginners
 Refer to some Tips and Tricks in this page
Strengthen your skills & network with peers!
👉 Join CATIA USER COMMUNITY to learn more about CATIA and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask questions, like and help in our online community!
👉 Join CATIA MBSE Cyber Systems to learn more about CATIA Systems Engineering.
👉 Join the 3DEXPERIENCE platform user's community to learn more about the 3DEXPERIENCE platform and to connect with your peers.
Increase your own skills or share your knowledge. Connect yourself with other users: ask a question, like, and help in our online community!
👉 Join the ENOVIA User Community to learn more about the ENOVIA brand and to connect with your peers.
Content type : User Success Path
Brand : CATIA
Role : STIMULUS
