Reference Images
3DXML:
Object Type Name: OT-Door-Revolving Door
Documentation:
Revolving door Parameters:
Mark: Free text parameter to record any project specific identifier for the door instance. Analogous to the “Mark” property in other BIM platforms.
Comments: Free text parameter to record any additional information for door instance.
Material: Only “Glass” is available.
Number of panels: Determines the number of door panels with available choices of 2,3 or 4.
Door height: Distance from the floor to the underside of the header.
Door width: Equal to the inside diameter of the outer curved glass.
Curve glass thickness: The outer curved glass panel thickness.
Panel thickness: The door panel thickness.
Bottom clearance: The clearance between the door panel bottom and the floor. This does not affect the door height. The value is always at least 1mm.
Door open angle: Determines the door panels rotation angle.
Door open direction: Determines direction that the Door open angle is measured from with “Counter clockwise” and “Clockwise” as options.
2D symbol: Enables the 2D drafting symbol in the model. Enabling this checkbox will also hide the geometry in the higher level of development models.
Door handle: Only “Push bar” is available.
Panel edges: For information only, available options of “Normal” and “Overlay”. To document if there is an overlap between the door panels and door frame.
Door edges: For information only, available options of “Normal” and “Overlay”. To document if there is an overlap on the door handle edge of the door panel.
Lock reinforcement: Information only, choose between “None”, “1 point”, “3 points” and “5 points”.
Drop seal type: Information only. Options are “Hardwood threshold”, “Sealed elsewhere”, “Painted steel threshold” and “Brush seal”. The drop seal geometry is always present.
Type of fixing: Information only, choose between “Plasterboard”, “White finish”, “Door frame and counter-frame”, “Tunnel frame”, “Drywall partition system with Omega profiles”, Precast plaster blocks” and “Renovation”.
Bottom fixings: Information only, choose between “None”, “2” and “4”.
Acoustic performance: Information only, with only “N/A” option.
Fire rating: Information only, with only “Not rated” option.
Anti-lift pins: Information only, choose between “None”, “2”, “3” and “4”.
Finish: Information only, choose between “Painted” and “Glossy white – RAL9016”.
Type of wood frame: Information only, choose between “Hardwood”, “Softwood”, “Softwood – 28dB rated”, “Hardwood – 28dB rated”, “Hardwood – 38dB rated”, “Hardwood – 40dB rated” and “Hardwood – 38dB rated – CL3”.
Type of frame: Information only, choose between “Unpainted”, “Laminated wood”, “2 profile molding” and “3 profile molding”.
