"DS_Customer_Parameter" and it would control the visibility of the main two outputs, the 3D model and the 2D symbol. 2. Symbol2DScaling This parameter is located under "Parameters" > "DS_Customer_Parameter" and it would control the scale of the 2D symbol. 3. Fixture Model This parameter is located under" />
Pendant - Circular
Pendant - Circular
Model 150mmD x 350mmL
Model 400mmD x 400mmL Splayed
Model 560mmD x 420mmL
Features embedded in the part
1. Visibility
This parameter is located under "Parameters" > "DS_Customer_Parameter" and it would control the visibility of the main two outputs, the 3D model and the 2D symbol.
2. Symbol2DScaling
3. Fixture Model
This parameter is located under "Parameters" > "DS_Customer_Parameter". Select here the desired model of this fixture type.
Models available in this dropdown are controlled by the design table of this fixture type and the reaction called 'Type'.
4.Luminiscent material
This luminescent material has been applied to a volume called 'Bulb' which would allow to create lighting renderings.
5. Electrical Ports
This fixture is compatible with electrical routing data setup, it includes with the following electrical ports.
6. Knowledge Template
This fixture includes a knowledge template which requires also an axis system as input to be instantiated.
3DXML
OT Pendant - Circular
