Escalator
Escalator
Furnishing type of an escalator. Object type includes an engineering template and UDF definitions for use with the Component Specification tool.
Pictures
Features Embedded in the Part
  1. Two-Way: Select between a single escalator, two side by side escalators or scissor escalators. The drafting symbol updates accordingly to indicate the bottom of each escalator.
  2. Show Drafting Symbol: Hide/Show the 2D symbol.
  3. Gross Story Height: Control the floor to floor height
  4. Inclination: Select the inclination of the escalator from a list of standard values.
  5. Top/Bottom Landing Length: Control the length of the landings after the end of the handrails
  6. Top/Bottom Slab Openings: Control the size of the slab openings for the escalator clearance
  7. Slab Thickness: Control the thickness of the base slab
  8. Step Width: Select the width of the escalator steps from a list of standard values.
  9. Divide Stairs By: Select the method by which the staircase will be divided into steps. The resultant rise and run of the steps is shown as parameters.
    1. Spacing: The number of steps is calculated based on the step spacing specified. The spacing is a diagonal measurement along the line of the staircase.
    2. Segments: The spacing of the steps is calculated based on the number of segments specified, a segment corresponds to a rise/run pair
  10. Top/Bottom Horizontal Steps: Control the horizontal run off distance of the escalator steps.
  11. Transition Radius: Select between standard radiuses for the transition of the handrail from incline to flat at the top and bottom respectively.
3DXML
Adaptive Object Type
Reference Object Type
