To generate a cut list, 2 options:
A. If you are working with the AEC data model (Civil and Building roles) check the following tutorial. This shows you how to create your own report and my report is downloadable there.
B. If you are working with a Structure role (SSX, STELM...) with Structure Design application, you can use the following report.
- Unzip the xml file.
- Go to Quality Rules Reuse App
Launch the Report Definition Command
- Click on File selection
Import the xml file
- Change the title if you want and save it
You can launch the report on your assembly from the Share menu, click on the arrow next to export to open the submenu and select Knowledge Report
