Chilled Beam - Active - 2 Pipes
Pictures
Features Embedded in the Part
Configurable port parameters that control the geometry of the piping.
- Finish: Select the type of cover plate
Grill
Solid
- Visibility: Change the visibility of the equipment between 3D representation, 2D representation or both.
- Plenum Size/Height: Select the overall size of the chilled beam plenum
- Chilled/Heated/Drain ports and Spigot horizontal and vertical offsets:
Horizontal: Controls the horizontal location of the ports using a ratio of the total width referenced from the mid-plane
Vertical: Controls the horizontal location of the ports using a ratio of the total width referenced from the mid-plane
- Plate Thickness: Change the thickness of the cover plate.
