Workbook 2022 HF2
Program
BIOVIA Workbook
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the release of BIOVIA Workbook 2022 HF2 which includes the following fixed defects.
Fixed Defects
User Story
Description
NBK-33737
Text section data now appears as expected, even after upgrade.
NBK-34119
When text and spreadsheet sections are ONLY edited via script, the changes are now always saved to the database.
NBK-34125
Workbook no longer crashes if more than one experiment using the Synthetic Chemistry functionality is open at the same time.
NBK-34163
Text section data now appears as expected, even after upgrade, without having to lock/unlock section.
NBK-34208
Browsing folders that contain many experiments performs better than in prior releases, for the second and subsequent times visited in the same login session.
NBK-34312
Very rarely, when multiple (more than 100) updates are made on a Vault object the Audit History now records all changes.
NBK-34341
Experiments containing text sections containing files with long names no longer cause errors on opening.
NBK-34342
Audit History no longer records erroneous changes to locked spreadsheet section cells.
NBK-34343
Workbook searches no longer retrieve search results where the searched term is in a section of an Experiment that has been removed from the Experiment in the current version.
NBK-34345
Fulltext search no longer fails for materials with long names.
NBK-34131
The "Save List" functionality in Workbook explorer now functions as expected.
NBK-34344
Workbook login times have been substantially reduced.
NBK-34347
Errors are no longer displayed when user clicks the "loading..." message in the QuickText panel.
NBK-34348
The system now interacts with the file service.log as expected.
NBK-34421
Workbook no longer throws errors when opening experiments if the QuickFile panel contains invalid paths.
Resolution
BIOVIA Workbook 2022 HF2 was released in June 2022 and is available for download at https://software.3ds.com under BIOVIA products and can be found under:
Product line: Lab, Scientific and Content Solutions
Release: July 2022
Level: BIOVIA 2022 Golden
Fixes for this level: BIOVIA 2022 Golden HF5
