Technical Note T53-2022
August 2022
BIOVIA® Foundation Hub 2022 SP1: Task Plan life cycle dropdown is empty when a Protocol runset life cycle action is defined in Hub.
Program
Operating Systems
Operating Systems supported by BIOVIA® n Hub See the System Requirements documents for details
Background
This technical note is to inform all BIOVIA Foundation Hub (v2022 SP1) customers regarding a known issue where Task Plan life cycle dropdown (“hamburger" button) is empty when a protocol runset life cycle action is defined in Hub.
Workaround
Instead of opening the task plan, customer can expand task plan view from foundation hub home page and use the buttons above the task plan grids to perform the actions instead of the hamburger menu.
Solution
BIOVIA is tracking this issue with DAT-23821 and the fix will be provided in the upcoming Foundation Hub 2022 SP1 HF1 and 2023 release where dropdown menu shows the correct actions to take for any Task plan life cycle with protocol runset life action defined.
BIOVIA Support
If you have any questions, please contact BIOVIA Support.
