Program
BIOVIA Foundation
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the release of BIOVIA Foundation 2022 which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA Foundation includes the following enhancements.
User Story | Description | |||
DAT-21183 | Enabled sorting and filtering on lifecycle policy column in Task Planner and widgets. | |||
DAT-12319 | Generic activity tasks can now transition to completed and released lifecycle states. Additionally, Generic activity tasks can be swapped for a method-specific activity before executing in Capture Hub. | |||
DAT-17978 | Revert buttons added to transition disposed samples back to collected lifecycle state and to transition abandoned tasks back to Draft/In Progress. | |||
DAT-19451 | Signature Policy enhanced to specify a group when the signer is Current User. When a group is set, it means the signer must be the current user and a member of that group. | |||
DAT-19802 | Added the ability to set a signature policy on the Active -> Upgrading lifecycle action in the Equipment lifecycle. | |||
DAT-20353 | Added the ability to define extended properties for equipment instances based upon their class. | |||
DAT-20639 | Added internationalization support (language files) for Korean, Japanese, and French. | |||
DAT-20650 | Relationship button added to manage associations between two tasks. System uses these relationship fields to when creating retest and review tasks. Lab Analyst can use these fields to define other relationships. | |||
DAT-20857 | Task Plan info card now displays the lifecycle status property. | |||
DAT-20971 | Hub configuration switch added to ensure unique names for Activities and Activity Plans. | |||
DAT-21438 | Confirmation dialogs added to the task abandoned, task recall, and sample return buttons. | |||
DAT-21440 | Titlebar above grids in Task Planner and widgets now displays 'filtered' when the grid is not displaying all the records. | |||
DAT-21449 | Relocated the abandon and delete buttons in Task Planner. | |||
DAT-21485 | Upgraded the Hub service to a newer release of AdoptOpenJDK 8. | |||
DAT-21489 | Upgraded the Hub service to a newer release of Apache Tomcat 8.5. | |||
DAT-21626 | Duration (hours) field added to the Activity page. | |||
DAT-21663 | Hub configuration switch added to view data across Collaborative Spaces from our widgets. | |||
DAT-21728 | Populated the relationship fields for existing retest and review tasks. | |||
SEC-6879 | The system now ensures the correct equipment is used during the execution of a metrology task. The selected equipment is pre-populated in the task and the Capture session and cannot be changed. | |||
SEC-7023 | A series of checks are performed when migrating activities or equipment before the content is imported into the system. The activities/equipment and their dependencies are analyzed and compared to what exists on the target system. The results are reported to the administrator in the import dialog. The information can then be used to guide resolution of any conflicts: keep the existing information on the target or use the source information. | |||
SEC-7026 | It is now possible to migrate one or more procedure activities into a Hub + Compose deployment. This includes importing the recipe into Compose. | |||
SEC-7027 | A new Migrations page has been added to Admin & Settings. Administrators with the Foudation/View Import and Foundation/Manage Import permissions can use this page to migrate content into their system. The page allows the administrator to select a file to import, then analyzes the content against the content already in the target system, and enables the administrator to resolve conflicts that are found. The administrator can then start the import of that content. | |||
SEC-7028 | It is now possible to export one or more activities or equipment. Administrators with the Foundation/Manage Export permission will see a new export button on the toolbar of the Activities and Equipment pages that will start the export of all selected activities or equipment and their dependencies (including recipes of procedure activities). | |||
SEC-7029 | It is now possible to export procedure activities and their dependencies (including the Compose recipe). | |||
SEC-7030 | Procedure activities can now be migrated into a Hub that does not have a Compose installation. These activities can be used to create and execute tasks in Hub Capture. | |||
SEC-7090 | Two new signature policies (Export Data and Import Data) were added and control the signing requirements of the export and import (migration) features, respectively. The signature policies can be edited to meet the customer's specific requirements. | |||
SEC-7317 | An administrator with Foundation/Manage Export permission can export one or more equipment records along with all dependencies (data packets, class readings, equipment type, equipment class, etc.) | |||
SEC-7344 | A new application setting was added that controls whether metrologists are allowed to override the next due date for a metrology event. The setting, "Enable Metrology Due Date Override" is found in the Equipment section of the Foundation Hub Application Settings. | |||
When enabled, an extra field appears on the metrology card in Admin & Settings: Override Next Due Date. The metrologist picks the next due date for that event and the logbook is updated with a comment stating the next due date was manually set. | ||||
SEC-7345 | Metrology tasks now include the equipment name and the metrology event name in the Task Name property. | |||
SEC-7369 | The default administrator account (scitegicadmin) no longer has a preset password. Instead, a password must be assigned to this account during configuration after initial installation of Hub. | |||
SEC-7474 | The user’s ability to edit the Materials List is now controlled by the Task Plan’s Collaborative Space. | |||
SEC-7476 | The integration gateway configuration is now part of the Hub upgrade process. | |||
SEC-7538 | File uploads are now limited to a preconfigured set of file extensions for better security. This affects adding a file in Compose during recipe authoring, uploading a file on the Data Preview page, uploading a file into an Observation in Capture, and uploading a file into a Task Plan file parameter. | |||
The default list of allowed file extensions is: txt, pdf, xls, xlsx, doc, docx, csv, jpg, png, zip, tmp. The list may be configured in the Hub application setting: Allowed File Extensions. | ||||
SEC-7545 | Groups, users, custom lifecycle policies, and Pipeline Pilot protocols are not migrated. They are, however, tracked in the export and will be checked against the target environment for corresponding items. If found, the import can proceed and the incoming content will be re-linked to the existing groups, users, custom lifecycle policies, and Pipeline Pilot protocols, If they do not exist, the administrator can create them and try the migration again. | |||
SEC-7552 | REST API added to extract all the materials, including PEX materials, used in a Task Plan. | |||
SEC-7632 | Superseded and withdrawn activities are no longer shown in the equipment event type selection list to help avoid selecting the wrong activity. | |||
SEC-7637 | Re-organized the Equipment UI links in Admin & Settings to improve their usability. | |||
SEC-7691 | A pre-configured client gateway for the Data Center location is now included with Hub by default. | |||
Fixed Defects
This release of BIOVIA Foundation includes the following fixed defects.
DAT-21358 | Switching collaborative spaces via the API now works correctly when using a bearer token. | |||
DAT-21718 | Fixed an issue that caused vocabulary-based extended properties to fail during import. | |||
DAT-21727 | System now prevents the user from entering a custom Sample ID that mimics the Sample Sequence Template regardless of ID length. | |||
DAT-22206 | Fixed an issue that could cause collected dates in the Sample dialog to display as "invalid date" when the client is set to a different locale than the server. | |||
DAT-22214 | Chain of Custody report now correctly displays when sorting on the event time column. | |||
SEC-7363 | A Task Plan opened in read-only mode now correctly prevents the user from scanning container IDs into the Materials tab. | |||
SEC-7853 | The Empower Add-In will now display up to 5,000 equipment aliases to select from when sending results that have no system name in Empower. | |||
SEC-7894 | When assigning a client gateway to a location, up to 5000 locations are now shown. Previously only 100 locations were shown. | |||
SEC-7925 | Fixed a problem that prevented transfer of a file to the client gateway for integration gateway-connected label printer equipment. | |||
DAT-13347 | Removed limitation on displaying >200 entries when editing a vocabulary. | |||
DAT-16378 | Resolved issue with displaying extended properties of quantity data type in Equipment pages. | |||
DAT-18893 | CSV/Excel export from the Task Plan Activity Results tab has been corrected to include units when "Pivot by Parameter" is applied. | |||
DAT-19606 | Task Planner now correctly validates invalid samples IDs in the presence of the manual data entry signature. | |||
DAT-20220 | Double-clicking the submit button in Admin & Settings no longer causes an error message to be displayed. | |||
DAT-20442 | Activity plan grid now blocks entry of non-integer characters in the upper limit and lower limit fields on a condition of type integer. | |||
DAT-20467 | System now blocks editing Equipment in the Approved lifecycle state. | |||
DAT-20683 | The system no longer displays special characters in the Admin and Settings Locations and Equipment pages. | |||
DAT-21031 | System no longer populates a task's Method Version field with the version of the Activity. | |||
DAT-21082 | Adding a new license no longer gives a parsing error when master data signing is required. | |||
DAT-21534 | Sample split action calculation corrected for the case when split unit (Each) is the same as the sample source amount unit (each). | |||
DAT-21553 | Manufacturer dropdown on the Add Equipment Type page now displays as many records as needed, up to the maximum allowed pagesize of 5000. | |||
DAT-21583 | The Location page now displays as many records as needed, up to the maximum allowed pagesize of 5000. | |||
DAT-21609 | The change summary of equipment audit history now displays both the barcode and the nickname. | |||
DAT-21698 | Admin and Settings > Users page now displays for the user assigned the 'Foundation/View Security' permission. | |||
DAT-21707 | Updated the Foundation Installation Guide chapters 2, 5, and 8 to clarify that Foundation should be installed first, followed by Pipeline Pilot, followed by the LabOps Collection (where appropriate). | |||
DAT-21748 | Admin and Settings page updated to correctly show recent changes to activities. | |||
DAT-21779 | Improved usability by increasing column widths in the Activity grid, Parameter Templates grid, and Vocabularies grid. | |||
DAT-21811 | A single-click or double-click on the Default Lifecycle Policy now opens the policy in read-only mode. | |||
DAT-21818 | Task Plan’s lifecycle menu now auto-hides when the focused is removed. | |||
DAT-21882 | The system now trims leading and trailing spaces from the name field when the Activity is saved. | |||
DAT-21942 | Barcode column added to the Lab Equipment widget. | |||
DAT-21967 | Fixed a problem that could cause the activity list to be empty when creating a new task. The problem occurred when the activity list had a saved filter ordered by life cycle policy name. | |||
DAT-21969 | System now ensures Task Plans shared outside of its owning Collaborative Space are read-only. | |||
DAT-22070 | User ID column added to the History pages. | |||
DAT-22103 | Admin and Settings > Add User dialog updated to prevent switching pages until after the new user is saved. | |||
DAT-22227 | The add and delete buttons are no longer active on the Sequence Templates page in Admin & Settings when the administrator has only Foundation/View Master Data permission. | |||
SEC-5278 | Changes to equipment events in the equipment type are now handled correctly on the equipment instance. The change no longer blocks the use of the event with an individual instrument. | |||
SEC-6824 | The metrology due dates of an instrument are reset when it is moved to a new equipment type. The metrology due dates of the old type are removed from that instrument and the new type's metrology events must be executed before the instrument will have a next due date. | |||
SEC-7328 | Corrected a problem that blocked electronic signatures when 3DPassport is configured as the authentication provider. | |||
SEC-7426 | Resolved a Materials grid display issue when there is a mixture of Hub Material extended properties for CISPro's Material and ReceiptLot properties. | |||
SEC-7499 | Sample collect behavior enhanced to trigger ‘Collection Failed” when the collected amount is greater than the amount from the CISPro container. System will now post a single event data message when collecting a sample. | |||
SEC-7826 | Fixed a problem that could cause the integration gateway to create archives of log file archives (*.gz.gz). | |||
SEC-7912 | Fixed a problem that prevented configuration of a file transfer point for integration gateway-connected file equipment. | |||
DAT-21915 | Life cycle action descriptions could be displayed in the audit history in a tokenized format instead of the intended human readable format. This issue has been fixed and the correct human readable format is now displayed. | |||
DAT-22176 | The system no longer displays special characters in the Admin and Settings Locations delete action. | |||
SEC-7774 | Updated the error message displayed when the location of an integration gateway equipment does not exist in the system to include the name of the expected location. | |||
Resolution
BIOVIA Foundation 2022 was released in December 2021 and is available for download at https://software.3ds.com under BIOVIA products and can be found under:
Product line: Lab, Scientific and Content Solutions
Release: 2022
Level: BIOVIA 2022 Golden
Fixes for this level: N/A
