Program
BIOVIA Foundation
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the release of BIOVIA Foundation 2021 SP1 HF1 which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA Foundation includes the following enhancements.
User Story | Description |
DAT-20915 | Updated Certificate lifecycle to support states needed for Hub Certificate Assignment and Lot Qualification. |
DAT-20917 | As part of the ULM lot certification functionality, there is a new Hub endpoint that generates a new Hub Certificate, Task Plan, Hub Material, Samples, and Tasks based on an "Approved" Activity Plan, a CISPro Receipt Lot and CISPro Material. |
DAT-21245 | Every hour Hub will check for expired Certificates and update their status. |
DAT-21326 | Certificates can now have a certificate of analysis file associated with them. As part of the ULM lot certification functionality, certificates of analysis can be generated from the Certificates widget. |
Fixed Defects
This release of BIOVIA Foundation includes the following fixed defects.
DAT-21193 | Hub now keeps the Activity Plan ID constant across all Activity Plan versions. |
DAT-21726 | System now prevents the user from entering a custom Sample ID that mimics the Sample Sequence Template regardless of ID length. |
DAT-21814 | Corrected issue with displaying of PLP Protocol lifecycle menu options from the Equipment page. |
DAT-21827 | Corrected an issue with executing Data Acquisition Activities configured with input parameters. |
DAT-21855 | Sample split REST API has been changed so the sampleIds argument is optional. |
SEC-7605 | Improved the equipment crawler handling of unexpected job results that could cause the crawler to stop. Added an API that can be used to manage the equipment crawler: check the status and reset the crawler jobs. Fixed some issues where Parse and Crawl hub jobs did not clean up correctly after unexpected termination/completion. |
DAT-20450 | Corrected an error in the documentation regarding the steps to disassociate a deleted vocabulary entry when editing a parameter template. |
DAT-21585 | It is now possible to save edits to child procedure activities when the recipe contains complex expressions. |
DAT-21656 | A JavaScript error is no longer displayed when copying data across rows in the Samples grid via the keyboard. |
DAT-21675 | The URI and URL validator now properly handles colons in the content of URIs and URLs. |
DAT-21893 | Audit history now displays correctly when it contains null values set via API in text-type extended properties. |
SEC-7521 | Resolved a Materials grid display issue when there is a mixture of Hub Material extended properties for CISPro's Material and ReceiptLot properties. |
Resolution
BIOVIA Foundation 2021 SP1 HF1 was released on 18 August 2021 and is available for download at https://software.3ds.com under BIOVIA products and can be found under:
Product line: Lab, Scientific and Content Solutions
Release: 2021
Level: Refresh3
Fixes for this level: HF1
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
