Program
BIOVIA Compose and Capture
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the release of BIOVIA Compose and Capture 2021 SP1 which includes the following enhancements and fixed defects:
Enhancements
This release of BIOVIA Compose and Capture includes the following enhancements.
User Story | Description | |||
CAPT-5322 | Capture Hub does not allow use of Disposed Containers for any process | |||
CAPT-5206 | Review signature audit history column names updated to be more discoverable and self-explanatory. | |||
CAPT-5426 | Information specific to container or batch has been removed from the Material row and broken out more logically. | |||
CAPT-3099 | Capture user will be able to execute a pipeline protocol on a step that the author has predetermined to populate specific parameters. Review will reflect the provenance of the protocol-determined values. | |||
CAPT-3881 | Completed, Abandoned, & Released executions will open to the first step with reviewable information. | |||
CAPT-3929 | When an execution is completed, Capture Hub page now remains open in Read Only mode. | |||
CAPT-3938 | Repeat option is moved from the status icon drop down to a repeat button that is visible whenever relevant. | |||
CAPT-4105 | Abandoning a sample now requires a Procedure Modification signature. | |||
CAPT-4840 | All information about Metrology and GMP warnings in signature events has now been added to the Recipe Report 2020 recipe level Equipment Table | |||
CAPT-4917 | Small equipment card on the step can be used to add ad hoc equipment. Equipment so added is documented as used on the step, rather than just in the recipe. | |||
CAPT-5053 | Included Additional fields Printed on: Date/Time (UTC), Printed by: User ID and Environment Label in BIOVIA Recipe Approval Report 2020 footer. Header is updated with Task IDs. Phrasing renders HTML | |||
CAPT-5116 | Capture user can now combine tasks made from separate child activities of the same parent Procedure activity. Some restrictions exist, in that tasks must have distinct samples, identical materials, and identical set of parameters. However, different sample level limits are allowed. | |||
CAPT-5205 | When samples are abandoned during execution, that information is made available for filtering in Task Plan Results. Also, validity is automatically set to "Abandoned" for parameter values coming from those samples. | |||
CAPT-5221 | Report generation has been made faster. This will have a larger advantage with larger recipes, where it should be much faster on a per-page basis. | |||
CAPT-5228 | In new Data Modification mode for Capture Hub, a signature is required for every update to any non-calculated Actual Value after initial data collection. This mode must be configured for the environment by the system administrator. | |||
CAPT-5792 | Signature policies in Foundation can be configured with Free-Form Comment Allowed. In this case, users can add comments while signing. Those comments are recorded and are viewable in Review and Report. | |||
CAPT-5926 | Admin can configure life-cyle transition actions to trigger a Signature Policy that requires multiple signers for Procedure and Data Acquisition Tasks. | |||
PROP-7992 | The Compose and Capture User Guide has now been added to the Compose and Capture 2021 SP1 documentation zip file. The user guide is a PDF version of the Compose and (classic) Capture online help. | |||
PROP-8663 | It is now possible to author a step so that parameter values on that step are populated by a designated Pipeline Pilot protocol during Capture Hub execution. | |||
PROP-9819 | Authors may now include sample extended properties to read into capture sessions with samples. | |||
PROP-10003 | When configured by a Compose administrator, a report is now available to indicate whether parameters are based on superseded parameter template versions, or if there is a version mismatch within the recipe. | |||
PROP-10005 | A report has been created to highlight changes required to any recipe before it will function properly in Capture Hub. The report can be made available by a Compose admin through the Manage tab, then can be run by any author. | |||
PROP-10094 | The default formatting for numeric and quantity units is "Raw". | |||
PROP-10188 | Compose now uses the same environment variable as Foundation, for display of "Production", "Validation", "Development", etc. | |||
Fixed Defects
This release of BIOVIA Compose and Capture includes the following fixed defects.
Defect | Description |
CAPT-5834 | Step repeat in Classic Capture handles calculation expressions for Activation Conditions correctly |
CAPT-3395 | Repeat step and sample is no longer limited by the number of rows in the step. |
CAPT-5685 | During Data Acquisition, only values for parameters with planned equipment in the sample mapped equipment are cleared before update. |
CAPT-5742 | UI displays step level observations collected on steps with the first sample deactivated. |
CAPT-5755 | New Observation file uploads can be downloaded by any user. Existing file attachments are not modified |
CAPT-5793 | New Observation file uploads can be downloaded by any user. Existing file attachments are not modified |
CAPT-5795 | Sample activation condition correctly propagates to child operations and actions |
CAPT-5813 | Sample-less steps in Abandoned/Abandon Pending states are now ignored during calculations. |
CAPT-5906 | Planned range is now displayed for integer parameter in Capture Hub. |
CAPT-5923 | Data Modification signatures collected for a parameter without a recorded actual value will now be properly displayed in Review. |
CAPT-6011 | Review now correctly records the Comment and Reason Codes strings. |
CAPT-6091 | Capture Hub successfully scans container barcode |
CAPT-6114 | Users are now properly able to select file-based equipment as a source when needing to add data manually. |
CAPT-6118 | Planned numeric value is displayed correctly in the grid header |
CAPT-6122 | Quantity and Numeric parameters with format method "Raw" and an actual expression that evaluates to 0 can now be correctly detected as Out of Limits. |
CAPT-6136 | New row is not added when scanned container is signed with bad credentials. |
PROP-10193 | Fixed an issue in which clicking on a drop down menu in the property mapping dialog was causing the UI to freeze when a recipe contains many steps |
PROP-10214 | Added and index in the AUD_CMP_RECIPE to prevent performance issues in environments containing large amounts of data. |
PROP-10218 | Valid expressions in Compose can now be written to include new line/carriage returns within the expression. |
PROP-10235 | If a Sample mapping is removed after an activity has been published, Capture Hub will no longer show parameters mapped to Samples. |
PROP-10240 | Reordering the Compose Recipe's Process Tree no longer breaks expressions. |
PROP-10254 | Import will no longer be prevented if a mapping reference either maps to a null value or maps to a resource that has been deleted. |
PROP-10259 | A null mapping is no longer added when a process parameter mapping is added after having deleted a process parameter mapping on the same process parameter |
PROP-10269 | Fixed an issue in which an error was thrown upon publishing an Activity from a Compose Recipe under specific conditions. |
PROP-10271 | Cloned recipes now contain the correct sample reference field associated with sample mappings. |
PROP-10272 | Removal of an activation condition now persists properly when the recipe is saved. |
CAPT-1657 | Out of Limits validation in cases where planned and actual non linear units are different now properly follows precision rules |
CAPT-4355 | The "loading" icon now properly disappears when Boolean and vocabulary parameters take some time to populate. |
CAPT-4467 | Review for Capture Hub executions allows multibyte characters in the reason code |
CAPT-4525 | The register icon is now properly disabled after a new batch of material has been registered. |
CAPT-4531 | Changed equipment behavior so that only one command will be executed at a time, rather than executing multiple commands that may not make sense together. |
CAPT-4583 | The error message has been corrected for cases where a parameter was not populated from a measurement, and the user selects, "View Measurement" from the context menu. |
CAPT-4914 | User is able to select day, month, and year for Date/Time parameter via calendar. Long Text parameters can be collected as expected |
CAPT-5297 | Reviewers are now properly able to view values from deactivated branches in Review and Report. |
CAPT-5306 | Activation Condition description is now visible when clicking on the "inactive" icon, not just on hover. This better accommodates touch screen displays. |
CAPT-5321 | Tasks with conflicting lifecycle states and planned units can no longer be combined. Capture Hub and Review have been updated to display all activity names. |
CAPT-5326 | The buttons that launch Review and Report have been modified for clarity and consistency, and tooltips have been added. |
CAPT-5359 | Long words without spaces now wrap correctly in Review audit trail |
CAPT-5404 | Fixed an issue in which double clicking the Next button sometimes caused incorrect display of the error, "This step cannot be changed. Already completed." after successfully navigating to the next step. |
CAPT-5494 | Improved display of cell contents when they exceed the width of the cell. |
CAPT-5568 | In Raw formatting, when planned and actual values use different units, values are rounded to at least 10 digits before limit evaluation. The issue is corrected in both classic Capture and Capture Hub |
CAPT-5630 | The Custom Property name shown in Review is matching with Compose |
CAPT-5646 | Audit table in Review is now formatted correctly on tablets in portrait mode. |
CAPT-5648 | Calculator length() function works as expected in Capture Hub |
CAPT-5658 | Fixed a Review issue in which, for certain tablets in portrait mode, not all validity choices were visible. |
CAPT-5682 | Arithmetic function cube() is now supported in Capture Hub |
CAPT-5696 | In cases where units are not properly matched between the Capture execution and the CISPro inventory, the user receives informative error message. |
CAPT-5703 | Capture Report 2020 now displays activation condition in the step title. |
CAPT-5721 | iPad Safari: After collecting value for non quantity parameter and pressing Tab key focus moves to the next cell instead of Browser URL |
CAPT-5747 | Validity for values deleted via trash icon can be updated |
CAPT-5761 | Capture Hub now displays a Read Only label when the execution is in a read only lifecycle state. |
CAPT-5777 | Review now shows Procedure Modification and Abandoned icons for materials. |
CAPT-5789 | Logbook entries for Direct vs Data Acquisition do align |
CAPT-5790 | Context Urn link shows child activity name when batch is registered from a child activity |
CAPT-5853 | Review for Capture Hub executions now allows special characters in Comment and Reason fields |
CAPT-5858 | Able to perform WF transitions from Review when user enters a freeform comment AFTER selecting a reason code |
CAPT-5865 | Activity field in Capture Hub Review displays correct value |
CAPT-5866 | Capture Hub and Review display the same activity version and name as Task Plan |
CAPT-5876 | 'Observation Exists' icons with an empty text no longer appear in Report and Review when an ad hoc observation was added and then removed during Capture Hub execution |
CAPT-5901 | Fill Down no longer updates values in repeated rows of Abandon Pending Samples and does not remove the Abandon Pending status from the Sample. |
CAPT-5946 | When threshold recalculates, only one Data Modification signature event is created |
CAPT-5965 | Capture Hub execution state transitions work with No Credentials signature policy |
CAPT-5976 | Material Supplier moved from Main Material Grid to the Container Sub Grid |
CAPT-5993 | In Horizontal View, after clicking Next, sample context menu shows as 'Done' |
CAPT-6006 | On steps with no samples, no materials, and with the first parameter flagged as "hidden", Horizontal View Grid will no longer crash. |
CAPT-6022 | Signature dialog Reason, WF options, Report and Unit list are not shown as links |
CAPT-6023 | When more than 100 Containers scanned for a Material all the container details are shown in the Container Grid |
CAPT-6050 | The Formatted, Raw, Planned icons now show properly even when column width is narrow. |
CAPT-6059 | Capture Phrasing is shown correctly when parameter expression in the phrasing is wrapped inside HTML tags |
CAPT-6082 | Signature is now accepted in Review without entering a reason code when not required. |
CAPT-6084 | Equipment card updates the used instance without adding any additional blank rows to the Card |
CAPT-6094 | Capture Hub execution completes successfully when sample is removed from the task |
CAPT-6139 | Measurement rows are grouped under single measurement sample, with arrow to expand and display all grouped rows |
CAPT-6148 | Classic Capture and Classic Review now correctly records the Reason Code. |
CAPT-6171 | Capture Hub now always uses the Pipeline Pilot server configured in Compose instead of defaulting to the first Pipeline Pilot application listed in Hub. |
PROP-9901 | Fixed in an issue in which the Instructions steps in Workbook were out of order on occasion. Instructions steps in Workbook's Recipe Section are now consistently sorted correctly. |
PROP-10155 | The '# figs' field on a parameter using the 'Decimal' display method can now be successfully set to zero. Both the original recipe containing the parameter and the clone of the recipe, either regular clone or cloning via 'Reopen for Edit', will be executable in Hub Capture. |
PROP-10157 | Expression Editor properly displays when there are a large number of parameters in the drop down menu. |
PROP-10175 | Fixed an issue with HTML encoding in the "Name" field of Compose's Recipe Filter. The name now displays correctly. |
PROP-10215 | Upon attempting to clone a recipe in which a Method Category hasn't been selected, we will throw an error alerting the user that they need to select Method Category which will prevent issues caused by a lack of Method Category selection. |
PROP-10228 | A scroll bar is now available in the Expression Editor preview panel which allows the user to view the entire Expression Editor preview. |
PROP-10229 | Fixed an issue in which Material Mappings were mapped to either a material with a null value or to a recipe material that has been deleted. Reports now generate successfully. |
PROP-10230 | The endOfDat() function will no longer evaluate without an argument. It will now return null and provide an error in the editor to alert the user that an argument is required. |
PROP-10273 | A Text Parameter's display name can no longer contain double quotes which will prevent issues with using text parameters in an expression. |
PROP-10275 | Warnings are now consistent when deleting recipe resources used in process parameter mappings. The user will be warned the resource is used in a mapping and will need to confirm to proceed with the deletion of the resource. |
PROP-10276 | Compose expression editor now warns the user if now() function is used in Capture Hub recipe, as Capture Hub does not support now(). |
PROP-10281 | Readings for Advanced Connect equipment is now properly shown when mapped to Type/Instance |
PROP-10294 | Fixed an issue in which the Recipe Upversion Report failed to detect signature policies. |
PROP-10296 | Parameter Context tags now persist in a cloned recipe. |
PROP-10299 | Fixed an issue in which the Signature Reason code was not recorded properly when it has no spaces and is multiple of four characters |
PROP-10306 | Process Element Parameter Display names will now use the regular space between words in the name rather than the NBSP. |
CAPT-5360 | When an item is repeated the view now shifts focus to the new row or column. |
CAPT-5666 | Made it clear that it is not possible to remove equipment in a read-only view of the execution. |
CAPT-5783 | When tasks cannot be combined due to conflicting planned values or precision settings, the error message now uses the parameter's displayName. |
CAPT-5816 | The Task completion confirmation Dialog header title updated to "Complete the execution" |
CAPT-5924 | Step with a removed ad hoc observation completes successfully |
PROP-10145 | Fixed in an issue that allowed users to edit expressions, but not save changes, when the Recipe was in a Read- Only state. Edits to expressions are now completely prevented when a Recipes is in the Read-Only state. |
PROP-10152 | Capture Report 2020 now displays "Less Than" (<) symbol in step activation condition description. |
Resolution
BIOVIA Compose and Capture 2021 SP1 was released on 04 June 2021 and is available for download at https://software.3ds.com under BIOVIA products and can be found under: Product line: Lab, Scientific and Content Solutions Release: 2021 Level: BIOVIA 2021 Refresh3 Fixes for this level: N/A
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
