Program BIOVIA Compose and CaptureDescription We are providing this Technical Note to inform you about the release of BIOVIA Compose and Capture 2020 SP1 Hot Fix 2, which includes the following:New Features CAPT-3438: Any time the original value of the equipment mapped parameter is changed, via an instrument or manually, if the Data Modification signature is configured for the recipe, it is required to complete the step. CAPT-3964: When a container is scanned, the material substitution signature is triggered only if the Compose Material Synonym does not match the CISPro Material Tradename/Synonym. CAPT-5119: You can now enforce a Manual Override signature policy for anyone executing the recipe: ¡ For data that must be collected from equipment, and that would require a signature (or set of signatures) if the data is entered manually instead. ¡ For data that must be collected from inventory, and that would require a signature (or set of signatures) if the data is entered manually instead. CAPT-5136: A new parameter template with the name Current Time is available to recipe authors that will enforce a Manual Override signature if other than the Now button is used in Capture. CAPT-5169: You can now enforce a Confirm Override signature policy for anyone executing the recipe: ¡ For data that must be collected from equipment, and would require a signature (or set of signatures) if the data is entered manually instead. ¡ For data that must be collected from inventory, and would require a signature (or set of signatures) if the data is entered manually instead. PROP-9705: When a scaling recipe with recipe material amounts created, the phrasing correctly displays the material amount in the recipe AND in the execution. The author is able to leave the material amount in the phrasing which displays properly in the authoring. PROP-9909: There is added functionality that allows an Admin User to control the visibility of step revisions in the Parameters section of the BIOVIA Recipe Approval Report 2020. Fixed Defects CAPT-5015: In advanced parsing, 'valueIndex', 'itemIndex', and 'groupIndex' all retrieve the X value, and post it to the parameter when multiple values are returned. CAPT-5093: Fixed an issue in which the BIOVIA Recipe Approval Report 2020 would occasionally fail. The report can now be generated successfully under these circumstances. CAPT-5113: Task plan results completed after the previous version (2020 SP1 HF1) with material container parameters and annotations will now show the proper collected parameter values in the results. CAPT-5118: For Optional Parameters, under the 'Actual Value' column in the report, the previously collected value is shown for null values. CAPT-5212: When a signed value is re-collected and a new value does not require a signature, the Recipe Approval Report 2020 shows the correct data. CAPT-5227: Fixed an issue in which inaccurate time stamps could be provided in the report. CAPT-5231: Capture will now only executes the commands necessary to fill in the readings defined in Compose. CAPT-5243: Fixed an issue in which reports on classic Capture would sometimes include a spurious entry related to the previous cloning of the recipe. CAPT-5247: Fixed an issue in which some events would be reported exactly in duplicate. PROP-9862: The Task Plan Results tab will now properly show a blank value for a parameter that was entered, then deleted during Capture recipe execution. PROP-9941: Renaming the sample no longer causes it to be removed from the Activity. Additionally, no error message is seen while saving the recipe with the mapped parameter. PROP-9951: The Material function in the Expression Editor now works correctly. PROP-9961: Errors are no longer thrown when a recipe sample is removed from the Activity once the sample is renamed after publishing the Activity. PROP-9962: Renaming a sample no longer causes issues with saving a Compose recipe. PROP-9963: Compose successfully removes expressions on Material Amounts, Capture Hub recipes no longer throw an error. PROP-9976: Fixed an issue in which equipment mappings were not visible in the user interface. Operating System All Operating Systems supported for BIOVIA Compose and Capture 2020 SP1 HF2Resolution BIOVIA Compose and Capture 2020 SP1 Hot Fix 2 was released on September 4, 2020, and is available for download at https://software.3ds.com.How to contact BIOVIA Support If you have any questions, please contact BIOVIA Support at https://www.3ds.com/support |
