Program
BIOVIA Compose and Capture
Description
We are providing this Technical Note to inform you about the release of BIOVIA Compose and Capture 2020 SP1 Hot Fix 1, which includes the following:
New Features
CAPT-3158: Link back to Execution from Inventory.
Fixed Defects
CAPT-4542: Metrology and container warnings are now saved when exceptions are signed.
CAPT-4732: The Data Entry signature is now properly shown as having been applied to optional data that was added after an entry was signed in Capture Hub and Classic Capture reports.
CAPT-4733: Recipe Approval Report 2020 now shows correct data for optional parameters if values were collected after signing Data Entry or Data Verification signatures.
CAPT-4745: Contributors are now properly restricted from releasing the completed execution when approved through a GxP Approval workflow and executed through a Task Execution workflow.
CAPT-4762: The user name attached to the workflow "begin" event is now properly replaced with a pseudonym when required for privacy.
CAPT-4847: Capture Hub executions inherit Format Method, Rounding Rule, and Reported Value Precision settings from associated task parameters tagged as Process Input.
CAPT-4896: Expiration Date of containers is set correctly during material registration in CISPro for all cases.
PROP-9780: When a recipe includes more than one workflow transition for a single signature event, all workflow transitions are now recorded in the recipe's Audit History and Report.
PROP-9804: Recipes intended for execution in Capture Hub are now hidden from selection through Workbook.
PROP-9806: Recollected values from equipment are now being shown in the report.
PROP-9816: Fixed an issue in which the Linux installer showed 2020 HF2 instead of the current version.
PROP-9835: Fixed an issue in which changes to the parameter tolerance type would not persist after the initial save of the recipe after that parameter was added.
Operating System
All Operating Systems supported for BIOVIA Compose and Capture 2020 SP1 HF1
Resolution
BIOVIA Compose and Capture 2020 SP1 Hot Fix 1 was released on June 5, 2020, and is available for download at https://software.3ds.com.
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
