Program
BIOVIA Compose & Capture 2019 Hot Fix 2
Operating System
All supported operating systems
Description
We are providing this Technical Note to inform you about the upcoming release of BIOVIA Compose & Capture 2019 Hot Fix 2.
BIOVIA Compose & Capture 2019 HF2 is a Special release.
BIOVIA Compose and Capture 2019 HF2 requires BIOVIA Foundation 2019 HF3 and BIOVIA Pipeline Pilot 2019.
Important! You must deploy the Foundation SSO for version 2019 HF3 after you have installed Foundation 2019 HF3 and Pipeline Pilot 2019.
BIOVIA Compose and Capture 2019 HF2 is supported with BIOVIA Workbook 2018 SP1 HF2 and 2019 HF1. BIOVIA Compose and Capture 2019 HF2 is supported with BIOVIA CISPro 2019 HF1 and 2019 HF2.
BIOVIA Compose and Capture 2019 HF2 is a full installer, which can be used for new installations. You may upgrade Compose and Capture from either version 2018 SP2 or version 2019 HF1 to version 2019 HF2.
It contains fixes for the following issues :
PROP-8277 - As a Recipe author, you may now define a Collaboration Group that can edit the Recipe.
CAPT-2258 - Improved the performance of Form View in Capture in Internet Explorer.
CAPT-2259 - Vocabulary Parameter expressions function correctly in Capture.
PROP-8279 - Folders created with non-English names are accessible in Internet Explorer.
PROP-8281 - Readings for Equipment mapped at the class level can be changed.
PROP-8283 - Fixed a defect that caused some Parameter attributes to be overwritten during recipe completion.
PROP-8336 - Fixed an issue in which sample parameters in recipes were published to Hub with incorrect names in some situations.
PROP-7991 - When you reopen a Recipe with calculated Quantity Parameters, it will not prompt the user to save if the user has not made any changes in the Recipe.
PROP-8155 - Date/Time parameters can be mapped to Equipment.
PROP-8275 - Planned values, calculated by expressions on Vocabulary Parameters, are saved correctly to the database.
PROP-8276 - Equipment mapping is cleared after removing the Equipment mapping from the Parameter, saving the Recipe and refreshing the web page.
PROP-8284 - The Expression Editor button has been removed for Annotations.
PROP-8403 - When you reopen a Recipe with calculated Numeric, Date/Time and Vocabulary Parameters, it will not prompt the user to save if the user has not made any changes in the Recipe.
Resolution
BIOVIA Compose & Capture 2019 Hot Fix 2 has been released in January 2019.
We recommend this Hot Fix for all BIOVIA Compose & Capture Customers running earlier BIOVIA Compose & Capture versions.
How to contact BIOVIA Support
If you have any questions, please contact BIOVIA Support.
